sugar
Even though I have retarded dreams of parallel and serial and what not I'm really looking forward for this to happen.
arkadiusz.makarenko
- Moderator Team
Branch!
<facepalm>
Thank you.
~ Stanislaw Lem
~ Stanislaw Lem
arkadiusz.makarenko
- Moderator Team
@terriblefire
May I ask what was your plan with RTC? I expected to see signals similar to any other edge connectors on small Amiga like for RTC Read and Write.
But to my surprise I couldn't find any? I couldn't even find them internally in CD32 (they exist only in signal glossary?)
The same question about floppy drive emulation. I can see some of signals on edge, but most of them are missing.
Does it mean that some of the functionality of amiga chipset need to be emulated as well?
Do you mind mentoring this, or are you completely feed up with retro hardware (read community)?
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
This would need to be done by emulating the response you get from the amiga clock port and let the CPLD/ARM decide what data to supply. So the CPLD would need to decode the clockport address and the ARM would feed the data.arkadiusz.makarenko wrote: 03 Oct 2020 23:28 @terriblefire
From Steady's website...
$D80000 to $D8FFFF 64 KB SPARE chip select (selected by SPARE_CS)
(The area of memory where the clock port resides)
$DC0000 to $DCFFFF 64 KB Real Time Clock(RTC) (selected by RTC_CS)
The region of $DC0000 to $DCFFFF is used by an accelerator card that has a built in clock as the RTC_CS signal goes to the A1200 CPU connecotr and can not be used if you have a clock, simple really!
Address lines A2, A3, A4 and A5 only are available. You can only access D16-D23 as well so this yields the following accessible addresses,
$D80001
$D80005
$D80009
$D8000D
$D80011
$D80015
$D80019
$D8001D
$D80021
$D80025
$D80029
$D8002D
$D80031
$D80035
$D80039
$D8003D
Why are the addresses odd?
To read/write to these addresses you need to perform word read/writes under the 68000 architecture.
arkadiusz.makarenko
- Moderator Team
Diagrom! Obviously.terriblefire wrote: 04 Oct 2020 09:58This would need to be done by emulating the response you get from the amiga clock port and let the CPLD/ARM decide what data to supply. So the CPLD would need to decode the clockport address and the ARM would feed the data.arkadiusz.makarenko wrote: 03 Oct 2020 23:28 @terriblefire
If you look at those addresses with DiagROM on an amiga with a RTC clock (A1200) you'll see what needs returned. I think you can also get the datasheet for one of the RTC clocks commonly used. Basically you need to decode those addresses and put the data on D31-D24 and assert DSACK0, A real clockport would put the data on D23-16 and assert DSACK1. The CPU get the data the same in either case.Code: Select all
$D80000 to $D8FFFF 64 KB SPARE chip select (selected by SPARE_CS) (The area of memory where the clock port resides) $DC0000 to $DCFFFF 64 KB Real Time Clock(RTC) (selected by RTC_CS) The region of $DC0000 to $DCFFFF is used by an accelerator card that has a built in clock as the RTC_CS signal goes to the A1200 CPU connecotr and can not be used if you have a clock, simple really! Address lines A2, A3, A4 and A5 only are available. You can only access D16-D23 as well so this yields the following accessible addresses, $D80001 $D80005 $D80009 $D8000D $D80011 $D80015 $D80019 $D8001D $D80021 $D80025 $D80029 $D8002D $D80031 $D80035 $D80039 $D8003D Why are the addresses odd? To read/write to these addresses you need to perform word read/writes under the 68000 architecture.
It is just few adress lines, so I can use cheap logic analyser to see what is happening.
I will have a look if stm32 will be able to respond quickly enough (on its own?). That what I found if there is no hardware interface, then on EXTI it takes forever.
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
You should be able to get an ARM to respond to an interrupt inside 1uS. Whole chip was designed to do this even since the ARM1. Something must be wrong.
This says you should be able to get 24 cycles latency.
arkadiusz.makarenko
- Moderator Team
That is what I seen just below 1uS.terriblefire wrote: 04 Oct 2020 12:34 You should be able to get an ARM to respond to an interrupt inside 1uS. Whole chip was designed to do this even since the ARM1. Something must be wrong.
IntroToCortex-M3.pdf
I just assumed that it is too slow.
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
Thats the same time it takes the CIA to respond so i think its fine.
This is even true on the CD32. The "CIA" addresses do not respond for 900ns. I think this is so that things that use those ports for timing still get the same results.
arkadiusz.makarenko
- Moderator Team
Hiterriblefire wrote: 04 Oct 2020 13:24 Thats the same time it takes the CIA to respond so i think its fine.
I have some more questions (let me know when you are fed up, please)
I have following dilemma.
I am looking at RTC chips, and implementing this should not be that difficult, my issue is that for me it looks like I was missing some address lines on ARM.
A1200 clock port pin /A1200 Address /RTC address /cd32 riser
30 /A2 /RTC_A0 /ARM A2
29 /A3 /RTC_A1 /ARM missing?
28 /A4 /RTC_A2 /ARM 4
27 /A5 /RTC_A3 /ARM missingI can see following ones A0, A1, A2 and A4
What can't I see here?
RTC chip address/data table
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
The solution to this is to assign one of the INTSIG wires to A5 in the CPLD.
assign INTSIG[x] = A[5]; etc.
This is why i have spare lines for. :)
