Hi there
I'll by trying to get TF running in my Mega ST and EmuTOS seems to be the easiest route. Is there anyone who could burn and sell me chips?
Regards
Sqward
Wanted: EmuTOS ROMs for Mega St
Re: Wanted: EmuTOS ROMs for Mega St
@sqward I put a plcc rom in with your TF card, or were you looking for 32 pin roms?
sqward
32Pins. I don't have an adapter sadly.
The adaptors are £12 for the exxos store but you also need a decoder for 256k Roms. Either that or two 32 pin to 28 pin adaptors and burn the boot rom that Agranlund used to load too from hard disk or floppy?
The Boot ROM image from agranlund is 192k, so another option might be to use 6x 27C256 EPROMS and change the ROM size links over...PhilC wrote: 27 Sep 2020 15:15 The adaptors are £12 for the exxos store but you also need a decoder for 256k Roms. Either that or two 32 pin to 28 pin adaptors and burn the boot rom that Agranlund used to load too from hard disk or floppy?
sqward
That was my preference for now: 6x64kb EPROMS.
I have some 27c256 that I can burn you an image onto. I'll have a go during the week and let you know
@PhilC The trick for me was to trim some 'rubbish' from the end of the image (some comment in the binary about the brutal end... which was present in more than one place!)
Without doing that, the files were too big for the pair of 27C512 EPROMS I had (courtesy of rubber_jonnie)...but they may fit in the 192k available with 6x 27C256...I just don't know.
If the image is too big, you can trim it down quite a bit using the above method.
sqward
Thanks mate!PhilC wrote: 27 Sep 2020 20:14 I have some 27c256 that I can burn you an image onto. I'll have a go during the week and let you know
