I've been searching on-line this morning and can't seem to get a straight answer to the question:
What EEPROM models are pin compatible with the sockets on a STFM (2 ROM) motherboard?
(Background: I need to make a pair of DiagROM-ST ROMs.)
STFM (2 ROM): What EEPROM chips are compatible?
Re: STFM (2 ROM): What EEPROM chips are compatible?
Not quite the answer to your question...but the TF DiagROM image will fit in a pair of 27512 EPROMS.
There are a few Microchip OTP EPROMS in 28 pin packages - Farnell has a few for example, including 512kbit.
So, if the pinout matches, they might be an option.
2 ROM's nope, none. Only 32pin EPROMS which you have to bodge fit.
This is why I sell dualtos boards. Some others on here have some EPROM adapters which should fit more layouts. I think it was @DoG who did some.
TBH I have a pile of 27C256s and just fit an extra 4 sockets :)
Otherwise I use exxos' DualTOS adapters.
Don't you only need 6x 27C256 for 6 ROMs? That gives you all 192k of ROM decode space...rubber_jonnie wrote: 25 Sep 2020 11:01 TBH I have a pile of 27C512s and just fit an extra 4 sockets :)
Anyway...if TF's build of DiagROM is good enough that will just for into 2x 27C512 (after you trim off the 'junk' at the end of each image)
Indeed, I meant to write 27C256 and wrote 27C512 because my brain is addled at the moment! D' ohJezC wrote: 25 Sep 2020 11:10Don't you only need 6x 27C256 for 6 ROMs? That gives you all 192k of ROM decode space...rubber_jonnie wrote: 25 Sep 2020 11:01 TBH I have a pile of 27C512s and just fit an extra 4 sockets :)
Corrected!
Oh bother! Oh well. No DiagROM for me this weekend then.
Know that feeling all too well :lol: especially when our kitten decides to have a mad half hour at 2:30 AM!rubber_jonnie wrote: 25 Sep 2020 11:27 Indeed, I meant to write 27C256 and wrote 27C512 because my brain is addled at the moment! D' oh
zzzzzzzzzzz...sorry, must have dozed off there :roll:
I feel ya, except our kitten is a 6 year old cat......JezC wrote: 25 Sep 2020 12:18Know that feeling all too well :lol: especially when our kitten decides to have a mad half hour at 2:30 AM!rubber_jonnie wrote: 25 Sep 2020 11:27 Indeed, I meant to write 27C256 and wrote 27C512 because my brain is addled at the moment! D' oh
DoG
If you got 2 ROM board you should be able to move 3 solderblobs and use 6 27C256 instead. Just split DIAGROM into 6 pieces. Otherwise you can use 2 32pin 27C010 and some wire to mod the 2 EPROMs to use DIAGROM on that. You don't need a pcb mod board but it for sure will be neater. I made some and I wrote it in my blog a while ago. Works as a normal 28-32 pin adapter (with ROM switch for 4 ROMs and external chip enable/select signal for decoder board).
Users browsing this forum: ClaudeBot and 148 guests
