MegaST 4 will not boot, but looks fine with diagnostics
Re: MegaST 4 will not boot, but looks fine with diagnostics
guus.assmann wrote: 03 Jan 2018 21:23 Have replaced the sockets, now two quality sockets with round contacts are in.
Still with these it doesn't work either. :( :shock:
However it was a very good idea. :)
:( Doesn't make much sense.
I would check the CE and OE pins on the ROM and make sure they are switching.. maybe broken trace/bad glue socket, from GLUE to ROM for chip enables, you changed the LS11 already.. but I think you should check the ROM select lines from GLUE to ROM sockets.
If TOS206 worked on another board, then onboard TOS104 isn't working, GLUE does decoding for that...
guus.assmann
Post by guus.assmann »
Finally, I found some courage and inpiration.
And solved the problem.
Jumper W2 had a bad contact.
But it was hidden below the body of the part.
So there was no or a bad connection from the decoding chip to the Eprom.
The board works fine again.
BR/
Guus
Users browsing this forum: ClaudeBot, gpt [bot], OAI-Search [Bot] and 6 guests
