SND Player now works on my EmuTOS setup.
General Discussion, STOS.
thorsten.otto
Re: SND Player now works on my EmuTOS setup.
Post by thorsten.otto »
Do you have a link to the soundfile?
Cosmic Puppet
Post by Cosmic Puppet »
Will do when I get back from Yoga, although I've just noticed that the file that plays on TOS 1.04 but not on EmuTOS is .SNDH wereas .SND seem fine. Will check it out (see if it's consitant to file extension) and provide a link when I get back.
Cosmic Puppet
Hi @thorsten.otto
Can't get it to repeat with other tracks annoyingly.
http://cube.gfxile.net/t/index.php?page ... 2149F&pn=1
It's when I try to play Decisive Factor by !cube that it stalls quite early in the track.
thorsten.otto
Hm, i cannot yet reproduce that. Can only test it on Hatari, but there it works as expected, both with an STE and an TT configuration.
Cosmic Puppet
thorsten.otto wrote: Mon Sep 07, 2020 6:49 pm Hm, i cannot yet reproduce that. Can only test it on Hatari, but there it works as expected, both with an STE and an TT configuration.
I'm a bit of a purist and like hearing the Actual chip. :D
Thanks for all the work you do.
P.S. Is there a way on real hardware to get EmuTOS to start in Low Res? It starts in Medium Res and then is switched from the menu. Some Demos work on EmuTOS that bomb on TOS 1.04.
thorsten.otto
Low-Res should actually be the default unless you changed the setting in the desktop, then save the configuration file.
Regarding snd player: can you confirm that the only difference in your setup is the tos version? Or are there also different auto-folder/acc running when you compare TOS 1.04 to EmuTOS? Should that be the case, please make sure that the hung is not caused by some resident program. We are currently trying to investigate this, but snd-player just uses the YM2149 chip, and beside Dosound() there is not much support for it in the OS, so everything is usually just done by writing to the hardware registers.
Cosmic Puppet
Hi sorry @thorsten.otto
It was my fault. It's turned out to be ANTIBOMB.PRG Crazy how it only screws up one song.
Got the track working in every resolution now. I've tested EmuTOS from floppy drive and from UltraSatan in all resolutions and it is just that program. Sorry again.
As regards Medium and Low Resolutions. I find that if I save the desktop after switching to Low Resolution it will remember that when switching between High and Low on the video adapter. If I save the desktop whilst in High Resolution, the Resolution will default to Medium when I select Low on the video adapter.
Thanks.
anodyne
Post by anodyne »
Cosmic Puppet wrote: Wed Sep 09, 2020 8:47 pm As regards Medium and Low Resolutions. I find that if I save the desktop after switching to Low Resolution it will remember that when switching between High and Low on the video adapter. If I save the desktop whilst in High Resolution, the Resolution will default to Medium when I select Low on the video adapter.
Thanks.
I've just done some tests on TOS 2.06 and EmuTOS 1.0 (under Hatari 2.2.1). I confirm that when the saved resolution in the .INF file is high-rez, and the attached monitor is a colour monitor, the Atari desktop boots in low-rez while EmuDesk boots in medium-rez. Unless there's a really good reason to be different, I'll fix that.
Cosmic Puppet
anodyne wrote: Thu Sep 10, 2020 3:27 am
Thanks.
Nice one @anodyne 8-)
Nearly 100% compatibility with everything now. Just some Demos that play on TOS 1.04 give this message on EmuTOS 1.0:
JAPAN.zip
(700.18 KiB) Downloaded 167 times
On TOS 1.04:
Then If I try to load MEETCUBE on TOS 1.04 I get this:
But on EmuTOS 1.0 it works!
MEETCUBE.zip
(65.53 KiB) Downloaded 158 times
Return to “SOFTWARE”
