Getting software to work on 68LC060
- Admin sponsor
Re: Getting software to work on 68LC060
BTW if anyone fancies porting Pocket Quake (Fixed point) to Amiga i think i have the Amiga related parts of AmiQuake in source form somewhere.
alenppc
- Moderator Team
Roadshow seems to work fine, but I can't find my PCMCIA network card so I can't test it properly.
Netsurf SDL crashes regardless of anything. Netsurf OS4 port won't start since it requires OS3.9 and I am only using 3.1 so I can't check it.
EDIT: I am out of ideas what to test next. If anyone wants me to try something specific let me know.
matt020
IBrowse
SysInfo
Directory Opus
Stunt Car Racer
F/A 18 Interceptor (I suspect this is going to run way overspeed :D )
Just general stuff like that?
SysInfo
Directory Opus
Stunt Car Racer
alenppc
- Moderator Team
OK I just found my PCMCIA network card and got it working pretty well with Roadshow.matt020 wrote: 01 Sep 2020 00:02 IBrowse
SysInfo
Directory Opus
Stunt Car Racer
Installed the new IBrowse 2.5 and it works well (need to use the 020 executable).
DOpus 4 GPL works, Sysinfo works. F/A 18 interceptor gets insane FPS.
Lukya
Allen
Do you need to install the 030 MMU libs etc?
- Admin sponsor
You really should install MMULib. Its the generic 68K MMU library of choice.
alenppc
- Moderator Team
You need the 68060.library & preferably the whole MMULib package. For the rest, use 030 executables (on rare occasions 040 exes also work, for example mpega.library), but generally speaking you want everything else to be in 020 or 030 flavour.
8 Bit Dreams
- Moderator Team
Alen, did You tried to install this Lib?
http://www.amibay.com/showthread.php?11 ... ary-update
alenppc
- Moderator Team
Yes, totally pointless. It does not emulate an FPU, simply removes the FPU managment code so even Femu crashes. Avoid.8 Bit Dreams wrote: 02 Sep 2020 21:10 Alen, did You tried to install this Lib?
- Admin sponsor
Dont use any speedgeek libraries. You cant use them with MMULib as they basically do the same thing.
Users browsing this forum: ClaudeBot, DuckAssistBot and 5 guests
