RTC Replacement
Current solutions and designs.
avctech
Re: RTC Replacement
Post by avctech »
I managed to check all the connections this morning and found that pin 15 (RXW) isn't connecting. It looks like when I removed the existing chip I must have damaged that track :oops:
The track for that pin isn't visible so does anyone have any suggestions on how I can repair it?
Cheers
Proud owner of an Atari Falcon and Atari Jaguar with CD (toilet) add-on.
atari030
Re: RTC Replacement
Post by atari030 »
I had trouble with mine and had to nut it out so I listed everything to buzz it out. The trace should run to U24+U52/Pin13 (ACIA). That ground plane is a bitch.
U64/Pin1 Power 5V
U64/Pin2 not connected or not used
U64/Pin3 not connected or not used
U64/Pin4 AD0 <-> U31/Pin41
U64/Pin5 AD1 <-> U31/Pin42
U64/Pin6 AD2 <-> U31/Pin43
U64/Pin7 AD3 <-> U31/Pin44
U64/Pin8 AD4 <-> U31/Pin45
U64/Pin9 AD5 <-> U31/Pin46
U64/Pin10 AD6 <-> U31/Pin47
U64/Pin11 AD7 <-> U31/Pin48
U64/Pin12 GND
U64/Pin13 RTCCS <-> U56/Pin75
U64/Pin14 RTCAS <-> U56/Pin76
U64/Pin15 RXW <-> U24+U52/Pin13
U64/Pin16 not connected or not used
U64/Pin17 RTCDS <-> U56/Pin55
U64/Pin18 is connect to C232, R243 and D11 on the motherboard backside
U64/Pin19 not connected or not used
U64/Pin20 not connected or not used
U64/Pin21 not connected or not used
U64/Pin22 not connected or not used
U64/Pin23 not connected or not used
U64/Pin24 Power 5V
avctech
Re: RTC Replacement
Post by avctech »
Thanks Atari030, all sorted now :)
avctech
Re: RTC Replacement
Post by avctech »
Thanks to everyone who helped me sort this out, your support and patience is greatly appreciated :thanksyellow:
Re: RTC Replacement
:bravo: :goodpost:
What was it in the end ?
avctech
Re: RTC Replacement
Post by avctech »
I screwed the track on Pin 15 😡 Anyway, some enamelled wire and 5 minutes, all fixed 👍
atari030
Re: RTC Replacement
Post by atari030 »
This week I'm doing tech support for a CSIRO cluster. I got much more satisfaction in seeing that Falcon working again. :-) Nice one.
avctech
Re: RTC Replacement
Post by avctech »
Switched Falcon on today, and it doesn’t boot ☹️
This is all I get...anyone got any ideas?
Re: RTC Replacement
Never seen that one before :shrug: like its in some test mode or something. Is the floppy light still flashing ?
Cosmic Puppet
Re: RTC Replacement
Post by Cosmic Puppet »
avctech wrote: 26 Aug 2020 20:27 I screwed the track on Pin 15 😡 Anyway, some enamelled wire and 5 minutes, all fixed 👍
Love that screen colour!
Return to “RTC (Real time clock)”
