Powerbook 190cs full refurbishment & re-cap
Hey guys,
Guess what, I also restore Apple machines lol :) You know why I was excited about this machine? Because MagicMac on an 040 Mac is an absolutely stellar experience! I can't wait to run some super fast Atari apps on this :)
Here is my post about refurbishing this lovely little machine. I've never worked on a PB before so it was a learning experience. I didn't photograph the MANY brittle plastic tabs/screw mounts I fixed with ABS glue - but yes, I had to fix many. Without the glue the machine would not screw back together, I'm glad I managed to save everything. I re-capped the machine with the best organic polymer smd caps from Panasonic. The machine had the worst battery leakage I have ever seen, luckily only a small section of the power/input pcb had any corrosion which I managed to fix.
The original passive screen was actually in good condition but the internal display cable was faulty causing these line artifacts. So I decided to order a new screen from a 5300c which is an active matrix LCD & a new display connector; note that the display connectors are different and you have to have the proper cable for the particular screen. There were also different brands used. FYI this particular type of screen is still available today in large quantities as it was a highly used industrial display. I will update this post with some model numbers to help people out later.
This machine has the full 40mb RAM! This is so great since they are hard to find these days
The battery looks to be in a sorry state... makes me wonder what the inside of the machine is like (the outside is pristine)
The insides have seen better days!
The copper base sheet is in such a state of corrosion it cannot be saved (I did try) so it had to be discarded
Luckily the PCB is untouched apart from a tiny segment of the power section
With a solution of 50/50 white vinegar & lemon juice I neutralise the acid
I bathe the screws in the same solution
The touch pad screw plastics had broken, but managed to repair them with some good ABS glue.
The PCB & body after being cleaned, much nicer!
The capacitors replaced with high quality organic polymer panasonics.
The 5300c display - I actually found an apple parts supplier in the UK that still had a 'new old stock' one sitting in their warehouse!
Yes it fits nicely - note, it requires the specific display cable for this model
Glorious 640x480 256 colour active matrix
She is happy :)
Hope you enjoyed this restoration! I have a couple of little things left to do: * replace the prom battery / * fit IDE > CF and re-install OS
Re: Powerbook 190cs full refurbishment & re-cap
An excellent restore! What's the brand/type of "ABS glue" you use?
It was this one:
https://www.ebay.co.uk/itm/372652376101
For acrylic and abs.
It's really nice. Doesn't stick to your fingers like super glue either, also doesnt leave any of that weird oxide layer super glue leaves.
Umberto1st
Post by Umberto1st »
Nice work
3)1040 stf/m, 2)Mega 4 ST, 1)STE, 1)Mega STE, 1)STacy, 2)Falcon 030
Recently I was shown a horror story of capacitors inside the screen inverter board & display unit going bad and ruining someones old powerbook. I then realised that although my screen was new old stock, the caps were still 30 years old and have a shelf life. I opened it back up and replaced the caps. FYI I didn't have the correct size SMD caps in stock, so I shoe-horned in some radials. Not pretty, but this stuff is on the inside of the screen so it's not like you see it :)
Good idea replacing the caps on the LCD board, those little aluminium surface mount caps are really nasty when they go, just one tiny one caused me hours of repairs on my Amstrad Alt-386.
Might I ask where you got your screen from? I am trying to get a battery for my Powerbook G4 17" and struggling like mad, so looking for any potential suppliers.
Nice resto BTW, looks like new!
@rubber_jonnie
From VIS:
https://www.applemacparts.co.uk/
Really nice old-school stockists. They know their apples from their pears ;)
Happy to recommend them as they did a good deal for me when I asked.
Steve wrote: 05 Oct 2020 17:23 @rubber_jonnie
From VIS:
Cool,thanks :)
Users browsing this forum: apple [bot], Bing [Bot], ClaudeBot, gpt [bot] and 11 guests
