I had a ste with flaky dma it did see the ultrasatan fine just turned all the files into garbage
:comp:
Tom
Not Dectecting UltraSatan Mini
MissZee
Re: Not Dectecting UltraSatan Mini
Yeah it has a micro usb port on the side which i have a cable plugged into and its powered from a phone charger
It may help. But yours seems totally dead. You could try @Steve if he can test the stuff for you.MissZee wrote: 19 Aug 2020 19:24 Yeah sadly dont have another ST to try , could it be anything to do with the CPU i read on here that can often fix certain issues. It being replaced i mean with one from the shop.
MissZee
Kind of at a loss then? i guess
@MissZee sounds like you need to ask someone to test that ultrasatan for you, then youll know which bit is the faulty bit.
MissZee
If i manage to get it tested and the Ultra Satan Works on a different machine ? What would the next stage be to working out the issue?
Well it all depends on your skill level. It may need diagnosing by someone who is well versed with fixing Ataris. It may take diagnosis with an Oscilloscope or just sorting out some dodgy soldered joints.MissZee wrote: 19 Aug 2020 20:29 If i manage to get it tested and the Ultra Satan Works on a different machine ? What would the next stage be to working out the issue?
@Steve is one such person,
MissZee
Is Steve local to Nottinghamshire?
Coventry, West Midlands
No worries I'll have a look, will email.
Users browsing this forum: ClaudeBot, Google [Bot], semrush [bot] and 1 guest
