4Mb MMU Socket Upgrade questions
polbit
Re: 4Mb MMU Socket Upgrade questions
Well, after I disabled on-board memory with the resistors and attempted boot, the machine would show nothing, wouldn’t even seek floppy. I wanted to go back to known good state, so I removed the upgrade, and connected the resistors back. Now everything works, but I get thin, black, vertical lines every 1/3 inch or so (mono screen) They don’t move, are completely steady... Any ideas?
Which resistors did you pull up to 5v? Do you have a picture? Also, if you connect 5v to the the wrong side of the resistors, it won't work.polbit wrote: 11 Aug 2020 16:44 Well, after I disabled on-board memory with the resistors and attempted boot, the machine would show nothing, wouldn’t even seek floppy. I wanted to go back to known good state, so I removed the upgrade, and connected the resistors back. Now everything works, but I get thin, black, vertical lines every 1/3 inch or so (mono screen) They don’t move, are completely steady... Any ideas?
You need to pull up R59, R60 & R61 at the end furthest from the RAM and connect all 3 to 5v. If you currently have 1MB installed you need to do the same for R71, R72 & R73 as per the guide here: https://www.exxosforum.co.uk/atari/last/4MBMMU/index.htm
You should probably run YAART You might have bad RAM or just video interference.
My bet is interference.
polbit
Ran two passes, RAM is OK.
Tried two shifters, reflowed all legs of the socket I had to install for it.
The only other change I’ve done is install a blitter socket (no blitter yet) but I did not open up the vias, so I don’t think that would impact it. The computer worked perfectly fine yesterday...
Is your power supply recapped at least ? ... But I think you are drifting onto another topic here relating to video interference not RAM issues.
polbit
I am using a Mean Well RD-50A for PSU right now, and it works fine in my main 1040STF with 4Mb RAM.exxos wrote: 11 Aug 2020 17:40 Is your power supply recapped at least ? ... But I think you are drifting onto another topic here relating to video interference not RAM issues.
Well video issues you should open up a new topic and concentrate on the ram issue in this thread. But noise on the video is a inherent issue on most machines anyway, so its unlikely fixable.
Also as mentioned, please post a image of how you disabled the onboard ram.
polbit
I just fixed a 520STF motherboard (replaced CPU), and want to attempt upgrading with the 4Mb kit again. With that said, can someone tell me exactly which 68R resistors do I need to lift and tie to 5V? This MB seems to have few extras...
It will be the 68R ones..
