Greetings,
The Atari ST was my third computer "back in the day". I loved to play Xenon, Virus and Starglider and I still have the disks. But I sold my ST. I bought another one a couple of years ago but have not spent the time fixing it. Now I am determined. I have the black screen with white border. I have had a look inside, which was really interesting, cleaned it up and have the same problem - which is good because it shows that I put it back together properly!
I am also into Spectrums, and have a lot of them, have a ZX81 that I fixed, MSX and more.
I am looking forward to getting on this forum.
Cheers,
popeymon :lol:
Newbie from Somerset UK
Re: Newbie from Somerset UK
:welcomewave:
:swave:
Welcome on board!
There's a few topics on diagnosing and fixing these sorts of problems. IIRC that's often a memory issue.
I think @rubber_jonnie amongst others has done several posts about this kind of problem.
Will try and point you to some relevant posts when I am online from home later today.
Welcome on board!
valfac
Welcome!
Here you will get in shape your Atari
Greetings,
Greetings,
White border and black screen generally means no memory, so I'd start off by removing the MMU and cleaning the contacts/tweaking the socket (https://www.exxosforum.co.uk/forum/viewt ... hilit=plcc)popeymon wrote: 06 Aug 2020 14:00 Greetings,
I'd also get a datasheet for the RAM and check 5v and GND are good across the board, and there are no shorts. Buzzing out all the address/data lines etc is worthwhile too.
I'd also suggest getting a diag cartridge and null modem cable to connect to a serial port on a PC. If a machine doesn't boot, then you may well be able to see diag data across serial, which is a big help.
popeymon
Thanks. I have ordered the Exxos diag cartridge. That is where I will start. I will also look at the MMU and the RAM.rubber_jonnie wrote: 06 Aug 2020 15:51White border and black screen generally means no memory, so I'd start off by removing the MMU and cleaning the contacts/tweaking the socket (https://www.exxosforum.co.uk/forum/viewt ... hilit=plcc)popeymon wrote: 06 Aug 2020 14:00 Greetings,
Nice job 😁
Higgy
How be on popeymon,
I think that makes at least 3 Wurzels now on this forum. :lol:
I am also in Somerset. We were all Amigas at school. Although some poor sod had a Dragon!
I also got most other consoles and computers, but only Atari I have is a Jag.
Users browsing this forum: ClaudeBot and 12 guests
