TF536 on A2000
68030 + SDRAM + IDE
GadgetUK164
Re: TF536 on A2000
Post by GadgetUK164 »
A500 R6 is fine =D Will test R3, R5, and A500+ later, but I would assume they will be fine. Correction regards CPLD temp, its about the same - so I will heat sink mine I think. Nice to see that same 3.6MB/s on the 500 too! It's fantastic!
Re: TF536 on A2000
GadgetUK164 wrote: Sun Aug 02, 2020 4:50 pm A500 R6 is fine =D Will test R3, and A500+ later, but I would assume they will be fine. Correction regards CPLD temp, its about the same - so I will heat sink mine I think. Nice to see that same 3.6MB/s on the 500 too! It's fantastic!
I have 4.4 mb/s on my 2000 now. So there is defo some small speed gains.
GadgetUK164
Re: TF536 on A2000
terriblefire wrote: Sun Aug 02, 2020 5:01 pm
=D Out of interest, are you using a CF card or SD card?
Re: TF536 on A2000
CF card.
alenppc
Moderator Team
Moderator Team
Re: TF536 on A2000
Post by alenppc »
It works on the A500 (testing on the rev5 now).
@edolnx and @ericgla, can you check this on the A2000?
edit: the IDE does seem a bit faster now.
snifferman
Re: TF536 on A2000
Post by snifferman »
I have tested tf536r2_2020_8_2.zip on my A500 rev8a 2MBchip(SOJ-mod) WB3.1,MMULib,LoadModule for scsi.device.
Turrican 2 has no sound problem on start demo.
Im using 64GB SD(samsung evo plus) and scsi.device 46.0 (scsi.device from http://wt.exotica.org.uk/test.html )
Sysinfo reports 9.98Mips and 4.6MB ide read speed.
There is a small CPU-speed improvment and major IDE speed boost (before ~3.3MB/s)
dalek
Re: TF536 on A2000
Post by dalek »
Hey @terriblefile - next time you do a build can you please include r1 firmware? Or should I physically bodge those 2x swapped IDE lines on my r1? (and if so which pins need swapping?)
ericgla
Re: TF536 on A2000
Post by ericgla »
I've only had time to do limited testing, but everything is looking good so far!
alenppc
Moderator Team
Moderator Team
Re: TF536 on A2000
Post by alenppc »
@ericgla that’s fantastic news. Thanks.
Re: TF536 on A2000
dalek wrote: Mon Aug 03, 2020 1:54 am Hey @terriblefile - next time you do a build can you please include r1 firmware? Or should I physically bodge those 2x swapped IDE lines on my r1? (and if so which pins need swapping?)
I dont want people using the forum to fine binaries long term. Github has what you want.
Return to “TF536”
