ubeswitch - video adapter.
jacolover
Re: ubeswitch - video adapter.
Hi, just received the MKVI from exxos, the little push button switch broke off, what kind of switch (part number) is it? I see its a 2-pole, is it a momentary contact or latching switch? Can I use the external switch pads to solder another switch onto it? Thanks!
ube
Hm. It’s K2-1823SA. But that shouldn’t happen. Check your inbox. :)
master of the bare pcb
Gbrigden
Hi,
Can you let me know when these will be available to purchase from your store please?
Thanks
Thanks
You need to keep a eye on this topic https://www.exxosforum.co.uk/forum/viewt ... =90&t=2144Gbrigden wrote: 28 Oct 2020 13:22 Can you let me know when these will be available to purchase from your store please?
guigui668
Hello @all, I PM Ube for the same thing, my adapters provide to me lots of vertical band, i cleaned all, adjusted the trimpot for the best but still vertical bands.
Any advice (Monitor is a dell 1411U 15kHz compatible and a standard RGB cable of 50cm) ?
Thoe worst picture is on my Mste, the best on the 1040 STF, might thing about PSU/caps ?
Thxs a lot.
Thxs a lot.
The adapters don't really do much in terms of video. Mostly its down to just old machines and problems with the scaling on the monitor etc. I know there's been several threads about this problem on the forum already if you have a look around.
ube
guigui668
Yeah, i did read some of them.exxos wrote: 21 Nov 2021 18:30 The adapters don't really do much in terms of video. Mostly its down to just old machines and problems with the scaling on the monitor etc. I know there's been several threads about this problem on the forum already if you have a look around.
The vertical lines are visible with clear colors, look like 'vertical' noise. I will make pictures sometime.
Thxs
