ide led stuck red no boot
Subzero79
tf536 no boot anymore from ide
led remains stucked and no boot
floppy boot ok mem test ok
go0se
Re: ide led stuck red no boot
Does it show the same behaviour if you try a different CF/SD adapter / card / cable ?
- Admin sponsor
If it worked before then i suspect one of your solder joints has gone bad.Subzero79 wrote: 28 Jul 2020 07:41 tf536 no boot anymore from ide
Subzero79
Cpld or ide reflow and multimeter test ok
I think cpld related i will reflow cpld joints
- Admin sponsor
Also.. look at the resistor networks under the boards. Although i'd expect that would just not find the IDE interface. Also try out the IDE test kit with the special firmware and test.adf. this will check for stuck interrupts etc.Subzero79 wrote: 28 Jul 2020 13:25 Cpld or ide reflow and multimeter test ok
https://www.exxosforum.co.uk/forum/viewt ... =76&t=3091
Subzero79
Flashed firmware and run tests all tests passed reflowed cpld and ide connector ide now flash one time and no detected at all cf ,how to fix tru witu my multimeter network resistors to ide and all ok
Need to try something else
alenppc
- Moderator Team
Try a different CF adapter and cable. The cheap Chinese ones break very easily (crappy solder)
ericgla
I initially thought there was an issue with the IDE interface on my board since I saw similar behavior. Once I plugged in my CF card the IDE activity light would stay on and my A2000 would not boot. During my testing I got distracted my a phone call, and to my surprise the machine started booting after ~4-5 minutes.
At that point I remembered someone mentioning in another the 'causes of slow disk access' thread that a bitmap is created for the entire drive at boot, and a large boot disk with a small block size will cause long boot times. Sure enough I changed my boot drive to 512mb and now my A2000 boots within 30 seconds from IDE.
Subzero79
test again ide with custom fw pass allok tested new cf to ide.
len stuck red and amiga reboots.
if i do a hot plug boot meny recognises cf card as cc0
changhed ide cable.
diag rom detects disk when im going to test disk stucka @ detect if interrupr blah blah
please help
memory test all ok
cpu stressed and ok
how i can resolve cf card works ok on win uae
help TF
changhed ide cable.
please help
memory test all ok
cpu stressed and ok
help TF
Subzero79
Fixed reflowed network resistor with new solder .china builders use minimum solder.now its all ok ,rollin fast thanks tf.im going to build a second one for my new builded amiga 2000 black pcb.
Users browsing this forum: ClaudeBot, Perplexity [Bot] and 1 guest
