BLiTTER in short 520ST
Cyprian
Re: BLiTTER in short 520ST
Post by Cyprian »
Got it!
Many thanks
Where I can find a BOM list?
http://260ste.atari.org
DoG
Post by DoG »
Cyprian wrote: 27 Jul 2020 09:14 Where I can find a BOM list?
The BOM is in the STBlitter_RevA.zip on his site. In the readme.txt. I attached a bom which I generated from Eagle and added the missing values. But you really should use readme.txt. Lots of other info there.
STBlitter_RevA.txt
Cyprian
Post by Cyprian »
DoG wrote: 27 Jul 2020 10:01The BOM is in the STBlitter_RevA.zip on his site.
thanks
---EDIT---
and agranlund's website for the record:
http://www.happydaze.se/stblitter/
EzdineG
Post by EzdineG »
Does anyone have any insight as to what is necessary for the ROM portion of this upgrade? I can see a somewhat blurry picture of two larger EEPROMS on the high / low sockets, but can't make out anything useful otherwise. Also if anyone knows, can the IDE be disabled but the ROM portion kept?
I'm going to build a few and have a go.
Thanks!
Mattu
Post by Mattu »
Hi @Oldskool
Did you have success with your blitter boards?
If you have one spare and want to sell then I can take it off your hands. If not then i think ill order some made.
Cheers
Matt
Oldskool wrote: 06 Jul 2020 18:26 PCB's have arrived.
Look pretty nice pcb. PNG
JoeFloyd
Post by JoeFloyd »
Exxos no longer can source the ST PLCC blitter (C101643 / I60611 / MM9092V), but the STE/Mega ST blitter can still be found fairly cheep.
STE Mega STE SMT MCU + Glue + Blitter 144 Pin IC C302183-002
This chip combines the features of several chips into a single package, and I wonder if the daughter board approach could be used to adapt the C302182 to the older ST. As far as I know, the blitter hardware has the same software interface across all implementations. That should mean that as long as the electrical / signal difference are accounted for, it should be possible to access the blitter hardware in the C302183 on an ST.
Joe
EzdineG
Post by EzdineG »
Best still has blitters for the original line:
http://www.best-electronics-ca.com/custom-i.htm
$40.
Mattu
Post by Mattu »
I tried Best for a blitter and some help with my double spring keyboard - they won't post to the UK because of some virus or other.
Has anyone used the STE chip just for the blitter?
I was thinking of using this project for the blitter:
https://www.exxosforum.co.uk/forum/viewt ... 159#p51159
What would be cool if this was added directly to @agranlund 's Blitter IDE card by someone with more skills and time than I.
All the blitters are the same IC...
tzok
Post by tzok »
They meant the integrated MCU/BLiTTER, used in the late STe/Mega STe units...
Users browsing this forum: ClaudeBot, SteveBagley and 9 guests
