CosmosEx - Setting up a shared drive with Windows 7
Various other hardware solutions.
Re: CosmosEx - Setting up a shared drive with Windows 7
exxos wrote: 26 Jul 2020 22:23
rubber_jonnie wrote: 26 Jul 2020 22:18 You don't need to put in a password, Windows already knows your password.
I don't have a windows password...
So when you reboot your computer you don't have to log in, you go straight to the desktop? Or do you type in a username and login without a password?
rubber_jonnie wrote: 26 Jul 2020 22:27 So when you reboot your computer you don't have to log in, you go straight to the desktop? Or do you type in a username and login without a password?
Turn on pc - windows flashy logo thing - desktop, that's it.
Boots right into admin account, i don't click or do anything at all.
exxos wrote: 26 Jul 2020 22:29
Right, so you're one of those....... :smackbum:
Ok, at this screen:
Click 'Share' and post a screengrab of it, we need to know the name of the user specified on this line here:
rubber_jonnie wrote: 26 Jul 2020 22:47 Right, so you're one of those....... :smackbum:
Those who don't like repetitive tasks ;)
@exxos
Ok, so let's confirm the current logged in user since you auto log in:
Open a command prompt and type the command: query user.
You'll get a result like this:
Post a grab of the result. I'm kind of expecting it to be "chris".
rubber_jonnie wrote: 26 Jul 2020 23:14 Post a grab of the result. I'm kind of expecting it to be "chris".
Ok, so the username you need to use in the CosmosEx configuration is chris.
If your user chris has no password, then your configuration will be like this:
Obviously you will need to substitute your own IP address.
If your user does have a password, I can't help you with that I'm afraid.
If you use DHCP then if your IP address changes then you will need to update the CosmosEx configuration, better to use a static IP.
rubber_jonnie wrote: 26 Jul 2020 23:26 If you use DHCP then if your IP address changes then you will need to update the CosmosEx configuration, better to use a static IP.
Done that.. yeah fixed IP I use anyway...
On the MOUNT.ERR log it says "operation now in progress" :shrug:
Only thing I can suggest now is to power of the ST, reboot the CosmosEx and see if it connects.
Time for bed said Zebedee, pick up on this tomorrow!
rubber_jonnie wrote: 27 Jul 2020 00:02 Only thing I can suggest now is to power of the ST, reboot the CosmosEx and see if it connects.
Still no go :(
Return to “HARDWARE ESSENTIALS”
