Figuring out the causes of slow disk access on the TF536
68030 + SDRAM + IDE
Re: Figuring out the causes of slow disk access on the TF536
Has anyone tried the 25Mhz firmware? I really need feedback if i am going to improve this.
PaulJ_2.0
Post by PaulJ_2.0 »
terriblefire wrote: 25 Jul 2020 10:15 Has anyone tried the 25Mhz firmware? I really need feedback if i am going to improve this.
My SD adapter failed to init and my CF card worked the same transfer speeds as 7mhz.
alenppc
Moderator Team
Moderator Team
Post by alenppc »
I tried it, no difference for me. It works the same as the other one, but I never really had any speed issues.
arkadiusz.makarenko
Moderator Team
Moderator Team
Post by arkadiusz.makarenko »
I have done some more comparison tests.
Amiga 500 Rev6 1MB Chip
I used this image https://drive.google.com/file/d/1Lzhb5M ... sp=sharing
SD2IDE on 2GB SD card - class 4
Boot time exactly the same. approximately 15 seconds
SysInfo
Standard firmware - 2,259 - 2,437 - 2,042
Experimental firmware - 2,097 - 2,215 - 2,069
I did run series of test using this : http://aminet.net/package/disk/moni/DiskSpeed42
Directory access - the same
experimental:
File Create: 2 files/sec | CPU Available: 97%
File Open: < 1 files/sec | CPU Available: 98%
Directory Scan: 13 files/sec | CPU Available: 96%
File Delete: 12 files/sec | CPU Available: 95%
standard:
File Create: 2 files/sec | CPU Available: 98%
Directory Scan: 11 files/sec | CPU Available: 96%
File Delete: 13 files/sec | CPU Available: 95%
Seek time - the same
experimental:
Seek/Read: 1007 seeks/sec | CPU Available: 21%
standard:
Seek/Read: 1020 seeks/sec | CPU Available: 21%
Read/Write/Create on FAST - Long aligned buffers - very similar results
standard:
Testing with a 512 byte, MEMF_FAST, LONG-aligned buffer.
Create file: 24413 bytes/sec | CPU Available: 96%
Write to file: 20721 bytes/sec | CPU Available: 96%
Read from file: 51 bytes/sec | CPU Available: 98%
Testing with a 4096 byte, MEMF_FAST, LONG-aligned buffer.
Create file: 11126 bytes/sec | CPU Available: 98%
Write to file: 11084 bytes/sec | CPU Available: 98%
Read from file: 50448 bytes/sec | CPU Available: 97%
Testing with a 32768 byte, MEMF_FAST, LONG-aligned buffer.
Create file: 11152 bytes/sec | CPU Available: 99%
Write to file: 11103 bytes/sec | CPU Available: 99%
Read from file: 435874 bytes/sec | CPU Available: 88%
Testing with a 262144 byte, MEMF_FAST, LONG-aligned buffer.
Create file: 11129 bytes/sec | CPU Available: 99%
Write to file: 11134 bytes/sec | CPU Available: 98%
Read from file: 2412768 bytes/sec | CPU Available: 39%
experimental:
Create file: 24924 bytes/sec | CPU Available: 96%
Write to file: 21259 bytes/sec | CPU Available: 96%
Read from file: 52 bytes/sec | CPU Available: 98%
Create file: 11150 bytes/sec | CPU Available: 98%
Read from file: 49430 bytes/sec | CPU Available: 96%
Create file: 11154 bytes/sec | CPU Available: 98%
Write to file: 11201 bytes/sec | CPU Available: 98%
Read from file: 472478 bytes/sec | CPU Available: 86%
Create file: 10476 bytes/sec | CPU Available: 98%
Read from file: 2095862 bytes/sec | CPU Available: 47%
My testing show that there is not real differences, on this particular tests which I have done it would even suggest that experimental firmware is slower, but I bet if I run it several times averages would be the same.
~ Stanislaw Lem
go0se
Post by go0se »
Tried the 25MHz firmware along with the 534 timings version on an unbuffered and a buffered card. The IDE speed and boot time were the same as the original Rev2b firmware.
I'm firmly in the "don't have any problem with the 536 IDE speed" camp.
go0se wrote: 26 Jul 2020 00:02 I'm firmly in the "don't have any problem with the 536 IDE speed" camp.
I've never seen IDE speed problems either. So unless i can reproduce somehow i've no way to fix it. And its not like i only have a handful of Amiga's I've tested this on 2 different A500s, a A2000 (although i did skip the 2b on this one) and a CDTV. All worked fine. :/
GadgetUK164
Post by GadgetUK164 »
go0se wrote: 26 Jul 2020 00:02 Tried the 25MHz firmware along with the 534 timings version on an unbuffered and a buffered card. The IDE speed and boot time were the same as the original Rev2b firmware.
I don't think there is a speed problem. I think maybe its people testing on the A500 and assuming they should be getting 1MB/s or more (when not using an MMU).
arkadiusz.makarenko
Moderator Team
Moderator Team
GadgetUK164 wrote: 26 Jul 2020 15:15
I think it red herring.
If there are complaints those might only be from people who had extremely overblown expectations.
Realistically 030 cpu, 64mb fast ram + 2,5mb/s ide is what you ever need on Amiga 500.
~ Stanislaw Lem
8 Bit Dreams
Moderator Team
Moderator Team
Post by 8 Bit Dreams »
That's right, it was about long booting time, amiga reads whole bitmap of the drive, so if Your drive is 8 or 16GB (yes, You can use large drives with KS 3.1.4) it will take ages to boot unless You make bigger block size as default..
snifferman
Post by snifferman »
Till now I have soldered 3 cards. All runs at 108Mhz main clock, and no ide problems (no ide buffers)
Im using firmware tf536r2_2020_04_22
Amiga 500+ soj-mod 2MB chip Kick 3.1
I tested few SD cards.
WB3.1, Load Module/scsi.device 46.0 (Don Adan from http://wt.exotica.org.uk/test.html),MMUlib
SD 64GB(samsung evo plus)
0 System partition 0,5GB SFS Block size 4096
1 soft 1,5GB SFS Block size 4096
2 soft 2GB SFS Block size 4096
3 Soft 53,5GB PFS3AIO Block size 4096
BOOT time-Power on (one reset for load moudle included) 34s
Keyboard Reset time 19s
Speed sysinfo 4.0 around 3.3MB/s for all partitions
Without LoadModule scsi.device
Boot time-power on 22s
keyboard reset 22s
sysinfo 4.0 disk speed 2.9MB
On small cards or big ones( but with small partitions only) i had boot time under 15s (clean WB3.1 + MMUlib)
SD 128GB was not recognized In system (not visible)
Return to “TF536”
