Atari Megafile PSU question
Repairs & upgrades.
AtariFox
Re: Atari Megafile PSU question
Post by AtariFox »
Tomswork wrote: Sun Jul 19, 2020 2:56 am The red wire goes over to the other outputs for the led. Do not hook it the front panel led.
Tom
So the cable labeled next to J5 goes to the hole marked LED in the second picture, above the two 5v lines?
Tomswork
Post by Tomswork »
Screenshot_20200718-234030_Samsung Internet.jpg (132.37 KiB) Viewed 4437 times
@AtariFox
Yes
Screenshot_20200718-234157_Samsung Internet.jpg (155.66 KiB) Viewed 4437 times
AtariFox
Post by AtariFox »
Thank you.
Tomswork
Post by Tomswork »
Let me know how the megafile is going
I have my megafile together last night with a 40 year old 277r drive and it reads fine but I cant write to it grrrr.
Tom
AtariFox
Post by AtariFox »
Tomswork wrote: Sun Jul 19, 2020 9:55 pm Let me know how the megafile is going
Tom
I'll let you know as soon as i get the wiring all done. The connectors wires from exxos are so small, so i'll need to join some extra wire onto it. I thought they'd be thicker xD
AtariFox
Post by AtariFox »
Hi again. After several hours of connecting wires, soldering and stuff, the PSU is complete and it power up the megafile board.
It also powers up and seems to send activity to the ST 238R too.
Unfortunately i have a huge issue. I've nothing to secure the drive with. And i can't power it on properly f it's touching the motherboard.
I have nothing capable of holding the drive at all.
Anyone have suggestions?
atari030
Post by atari030 »
A nice big chunk of anti static packing foam under the drive is the old go to that works for bench testing. Or are you after a permanent solution?
Tomswork
Post by Tomswork »
The bracket that holds the hard drive on the the megafile case are backwords
@AtariFox
Tom
AtariFox
Post by AtariFox »
atari030 wrote: Wed Jul 22, 2020 5:14 am A nice big chunk of anti static packing foam under the drive is the old go to that works for bench testing. Or are you after a permanent solution?
Permenant. Since it wont always be out of the cupboard.
AtariFox
Post by AtariFox »
Tomswork wrote: Wed Jul 22, 2020 5:27 am The bracket that holds the hard drive on the the megafile case are backwords
@AtariFox
Tom
Oh they are? I'll try later to see if i can get it right. They didnt seem to want to line up any other way.
