cosmosex shared drive not working
Re: cosmosex shared drive not working
Tomswork wrote: Sun Jul 19, 2020 11:11 pm Yes that should work.
Either no change or it says "folder cannot be shared" . I bet this would have all worked fine in XP :roll:
Tomswork
Post by Tomswork »
Yes work simple in xp. The problem is the rights I would suggest a login in as administrator. Create a account name atari with name and password. Create the share and add the account to the share. Give it full rights to the share you administrator rights are blocking the share common problem with 7 and 10
Tom
Check that Windows hasn’t removed support for CIFS V1.
Open Control Panel -> Programs and Features -> Turn on/of Windows features.
If necessary, turn on CIFS V1 server and client and remove CIFS V1 auto removal.
@stephen_usher
Tomswork
Post by Tomswork »
This is a old windows 7 solution.
Tom
Its always been turned off...
I'm calling it a night away now. I just don't think its going to work.. I just dont get how it was working "once" just fine, then just stopped. Maybe some windoze update screwed it all up, who knows :roll:
@exxos can you post a pic of the CosmosEx shared drive config please
rubber_jonnie wrote: Sun Jul 19, 2020 11:53 pm @exxos can you post a pic of the CosmosEx shared drive config please
https://www.exxosforum.co.uk/forum/viewt ... =10#p44739
mikro
Post by mikro »
Btw, it's easier to try this stuff from the Linux console. So either connect your CE's RPi to a USB keyboard + HDMI monitor or set it up using another notebook running Linux. That way you'll see the error messages, hints what to google for etc.
I don't have a Linux PC :( I could build one, but just not got the time unfortunately.
Locked
