My success was to name the server ip..
in the shared drive I just put /atari (my folder) no ip address anything.. just exactly what the folders name was.
James
cosmosex shared drive not working
Bikerbob
arkadiusz.makarenko
- Moderator Team
Re: cosmosex shared drive not working
Long shot... but I had very similar issues recently.exxos wrote: 01 Jul 2019 10:43 I had this all setup last year, but connecting it back up... nope..
The shared drive is on my PC, and //CHRIS//SHAREFOLDER does bring up the folder on my PC.. but //192.168.0.2/SHAREFOLDER doesn't ? The IP address if correct for my PC.. but I assume this is why cosmo is failing to access the folder..
..anyone any ideas what's going on ?
Windows 10
https://support.microsoft.com/en-us/hel ... in-windows
~ Stanislaw Lem
~ Stanislaw Lem
So I recently got mine working again on my MSTE, and the problem was fixed by changing the login.
I have a Windows domain, so I was pointing at a share on a Windows 2012 server and was using the username in the format of: Domain_name\username.
You'd expect this to be the case, but it wouldn't mount on the CosmosEx. It had been this way since an update so I can only assume there was some sort of Samba update. I took a punt and removed "Domain_name\" leaving just the username, and it sprang back into life and has been fine ever since.
What I do need to do is check and see if that format works for a share on a Win7 PC on the same domain, which I'll do and report back.
I think I tried all sorts of combinations and gave up in the end. The annoying thing about it all, is once its all setup and working, I'll not use it for a week, to back and its not working again.
I may give it one last try in my H4, but likely I will just put it up for sale as I just dont have endless hours of free time to keep throwing at stuff :(
Ok, I just did a quick test to a Win 7 PC with a share, and it's working fine using just the username.
So my suggestions are:
1. Don't use a format of Domain_name\username
2. Don't use a format of PC_Name\username
3. Don't use a format of IP_Address\username
Simply put your username instead as below:
Looking at the CosmosEx web config page (The one on the CosmosEx itself, not Jookies home page, it does create the string of IP_Address\Share_Name so I think it is probably automatically creating a username of IP_Address\username.
I may try and verify this with a network packet capture, but it would explain the use of any of the above formats failing.
if I get back early enough tonight I will give it a try. Though I don't think I even set the folder up with a password. It was all just public as in had trouble getting it to work in the first place.
Be interesting to see how you get on.exxos wrote: 19 Jul 2020 10:58 if I get back early enough tonight I will give it a try. Though I don't think I even set the folder up with a password. It was all just public as in had trouble getting it to work in the first place.
No need to use \\Share_Name either, just Share_Name.
I tried every combination I could think of for all settings. Would be interesting to try on a H4 anyway as it has all known fixes done whereas before I would have been using a original board.rubber_jonnie wrote: 19 Jul 2020 11:03 Be interesting to see how you get on.
@rubber_jonnie
Tomswork
Maybe look at your windows share path with another computer on the network. Windows sometime puts is machine name in the network path.
Tom
Tom
Users browsing this forum: Bing [Bot], ClaudeBot, petal [bot] and 8 guests
