Can MiNT make use of the 64MB Fastram under TOS 2.06 ?
https://freemint.github.io/
... look at snapshot.
TF536 (ATARI) and Fastram and MiNT ...
frank.lukas
Re: TF536 (ATARI) and Fastram and MiNT ...
I looking for someone with a TF536 that can test it. EmuTOS works also fine with MiNT/XaAES.
frank.lukas
When maprom can not work with MiNT I can do nothing with the TF536 ...
https://github.com/agranlund/tftools
agranlund
Couldn't you just use 192kb version of EmuTOS?
You only need it for loading Mint from disk into ram anyway so even if that emutos lack desktop it doesn't matter
- Admin sponsor
Aww someone changed the subject line.. i wanted to see MiNT running on an Amiga... :)
agranlund
Also youd could try just the fastram installer for tos206. Not sure it makes sense to put tos in ram anyway if it just going to boot into mint (which is going to be in ram)
Or is tos still in use even when mint is running?
I posted it in another thread but im not sure which one, @exxos might be able to help :)
agranlund
Haha and I'm the opposite way around.. Casually Looking at Aros sources pondering how much work it would be bringing the superior OS to Atari :)terriblefire wrote: 16 Jul 2020 17:17 Aww someone changed the subject line.. i wanted to see MiNT running on an Amiga... :)
- Admin sponsor
I need to properly test this out on the cd32 at some point.agranlund wrote: 16 Jul 2020 17:27Haha and I'm the opposite way around.. Casually Looking at Aros sources pondering how much work it would be bringing the superior OS to Atari :)terriblefire wrote: 16 Jul 2020 17:17 Aww someone changed the subject line.. i wanted to see MiNT running on an Amiga... :)
I never used MiNT (well maybe once 20 years ago :lol: ) . Though I assume it gets set with PRGFLAGS to run in alt-ram with NVDI. In which case TOS probably doesn't used for much, maybe DMA stuff I assume, where fast-ram isn't going to help with that anyway.
agranlund
Try this as the first item loaded from your auto folder:frank.lukas wrote: 16 Jul 2020 12:34 When maprom can not work with MiNT I can do nothing with the TF536 ...
fastram.zip
It'll make sure TOS206 knows about the TF536 fastram, in case Mint is depending on TOS to provide that info instead of searching for the memory itself.
(I don't know much about Mint)
Or use EmuTOS to boot your machine and load Mint, in which case you don't need to do anything.
Maprom and Mint will most likely not work well together.
Mint rebuilds the MMU table for its memory protection stuff and that will completely trash the mapping that Maprom did to put ROM-TOS into Fastram.
But if you're running Mint, is ROM TOS used for anything much anyway? The kernel, xaaes etc will be running from fastram anyway..
If you absolutely want ROM-TOS in Fastram and it makes a difference even in Mint then you can solve that by loading either EmuTOS or 206 into fastram without using the MMU.
EmuTOS is the easiest. It's just a matter of recompiling it for this purpose. It's supported but not part of official releases.
For TOS206 there's the old TTRAMTOS program talked about in another thread.
But yeah, as far as I know it's early stages on the Atari still. I'm not sure if anyone got working IDE on the card yet?
