UbiSoft MV16
Re: UbiSoft MV16
I've got one of these carts somewhere in my endless stash.. Question I have is what other programs used this cart other than BAT/BAT2? Please say trackers/mod players!
weav
weav
Re: UbiSoft MV16
Trackers and mod players.
According to Atari Forum:
https://www.atari-forum.com/viewtopic.php?t=9824
B.A.T.
B.A.T. II
Music Master
Some MOD-Players
Audio Sculpture
Digi Composer
TCB tracker
Noisetracker 1.5
It should be the same, as Protracker ST saysy 'ST Replay', but MV16 workst with that setting.
B.A.T.
B.A.T. II
Music Master
Some MOD-Players
Audio Sculpture
Digi Composer
TCB tracker
Noisetracker 1.5
- GadgetUK164
Re: UbiSoft MV16
Main thing I am hoping to use it with is the new ScummST port!
Re: UbiSoft MV16
If the replay routine of both devices is the same as stated in atari forum a St replay cartridge will also work if you have one of those.
I think I have one somewhere but I can’t try it yet.
Re: UbiSoft MV16
Excellent! Now I just gotta find it!!
Re: UbiSoft MV16
Finally found the source for Griff's player on Maggie 8 that plays via the MV16. Wrote a silly/sad player long time ago that used an older version of his playrout. Below is the source and the compiled prg so you can test.. still gotta find the damn cart!
weav
weav
Re: UbiSoft MV16
Tried a few trackers on my Atari H4 board.
Ran Digi Composer and Noise Tracker 2 with MV16 output and it worked fine. ST Replay output also worked but was a bit lower in volume. Don't know why.
Tried Audio Sculpture v1.5 beta but it wouldn't load. Complained about to low memory but I got 4Mb. Tried it on a TT and it complained on that system also. So couldn't run that program.
Tried TCB Tracker v2.0s but I have no idea how to change output in that program so...
Re: UbiSoft MV16
@weav Can I suggest uploading the files you've mentioned to the forum, as it prevents posts from breaking if for some reason the site goes down or the link changesweav wrote: Mon Jul 06, 2020 1:49 am Finally found the source for Griff's player on Maggie 8 that plays via the MV16. Wrote a silly/sad player long time ago that used an older version of his playrout. Below is the source and the compiled prg so you can test.. still gotta find the damn cart!
weav
Re: UbiSoft MV16
Edited to attach the file in the post. Still on probation so have to wait for it to be approved by admins.
