TF536 IDE speed
68030 + SDRAM + IDE
kulamario
Re: TF536 IDE speed
Post by kulamario »
Here are photos of my processors under a microscope you can not see the remains of the previous name, but you can see a very similarity pay attention to the number six and two dots of paint on it are identical to all three cpu
alenppc
Moderator Team
Moderator Team
Re: TF536 IDE speed
Post by alenppc »
terriblefire wrote: Wed Jul 01, 2020 9:51 pm Im a bit confused about the 330 vs 536 thing...
Mostly because not only is it the same verilog code in both boards but 66% of the traces are identical. Its a literal copy and paste job.
Strange.
The A500 is a very strange beast. For example the 536 will boot at 40 MHz (80 crystal) but only on a rev5 motherboard. On rev 6 and up it just gives a yellow/red screen at boot.
I know it wasn’t intended to work at 40 but I wanted to try anyway since there are no issues on the CD32.
Plus, doesn’t it have to slow down to 7 MHz vs 14 when accessing the motherboard? That may have something to do with it. Maybe some CPUs don’t like running at 7.
EzdineG
Re: TF536 IDE speed
Post by EzdineG »
Strange.
Power supplies are different between CD32 and wedges. I know it’s a different design and may be unrelated, but most had problems getting stable 50mhz even on TF534.
Maximilian
Re: TF536 IDE speed
Post by Maximilian »
arkadiusz.makarenko wrote: Wed Jul 01, 2020 9:25 pm Is it that CD32 is more tolerant than A500?
For some reason my post wasn't posted, I asked the same thing.
I would love to see the CPU voltage and see the ripple on a scope for both the CD32/330 and an A500/536 .
Higgy
Re: TF536 IDE speed
Post by Higgy »
I am using a A500 psu on my TF360 CD32.
I just added a CD32 cable to the existing AMIGA one (i don't power a wedge & CD32 at the same time off it).
I did recap the psu and replace a couple of resistors which always show heat damage.
Re: TF536 IDE speed
alenppc wrote: Thu Jul 02, 2020 1:04 am The A500 is a very strange beast. For example the 536 will boot at 40 MHz (80 crystal) but only on a rev5 motherboard. On rev 6 and up it just gives a yellow/red screen at boot.
The CPUs shouldnt be unhappy with 7 but the clock signal rise time on the A500 is like a fortnight. I didnt add the buffer chip from the 534 because i didnt want more clock delays and figured with my approach i'd never get metastability...
You will probably need a phase adjustment for 40Mhz on a 500. I'll maybe come back to this after I get the these 060 bugs sorted.
arkadiusz.makarenko
Moderator Team
Moderator Team
Re: TF536 IDE speed
Post by arkadiusz.makarenko »
Do you think it would be worth trying 90mhz oscillator with the set up as it is? Or this definitely would not work?
~ Stanislaw Lem
snifferman
Re: TF536 IDE speed
Post by snifferman »
I have some fake cpu's from time when i was overclocking ACA 1233 on A1200. I have 4 of them and 2 orginal 40Mhz.
Some of them are running at 49Mhz and rest is crashing over 45mhz.
I have not test them on TF536 yet, but if yours will run with 98mhz oscillator, than its not a big diffrence to 100mhz
Btw. I soldered one of my TF536 and it runs fine at 108Mhz (CPU-54Mhz)
Re: TF536 IDE speed
This is getting off topic guys. Start (yet another) new thread about fake CPUs.
Subzero79
Re: TF536 IDE speed
Post by Subzero79 »
Control
Return to “TF536”
