Welcome
I done my 5 boards but I think is something wrong speed in SysInfo show me 600-700kb/s when i write in shell
CPU Fastrom i have up to 2mb/s
Another think games like Doom and Nemac start freeze after some time
I check this on CF Card and SD Card
Procesor from Ebay 030 50mhz
System 3.1
and as well I check this on 3.1.4 on this one max transfer what I get was 650kb/s
Please any advice with this
TF536 IDE speed
PaulJ_2.0
alenppc
- Moderator Team
Re: TF536 IDE speed
Sysinfo is awfully bad at this. For more accurate results you should use a specific disk transfer benchmarking software, such as diskspeed. But as you've confirmed, FASTROM improves transfer.kulamario wrote: 30 Jun 2020 12:36 Welcome
And there is your problem. It's most likely a fake/reprinted CPU. Want to find a sure fire way to make it crash? Download memcheck12.lha from aminet and run it on fast ram. It will make a fake/reprinted CPU crash at some point.Another think games like Doom and Nemac start freeze after some time
- Admin sponsor
Re: TF536 IDE speed
This is well known and well documented. This is what you get. Its because without fastrom the scsi driver is running out of slow rom.kulamario wrote: 30 Jun 2020 12:36 Welcome
On CD32 you can get 1.4Mb/s without fastrom and 2-4Mb/s with it.
kulamario
Re: TF536 IDE speed
Problem sort thanks lads
Now must find what is going on with this two games
When I left super frog for whole night run without problem same frontier working perfect but Doom and Nemac no want
matt020
Re: TF536 IDE speed
What was the solution??
- Admin sponsor
Re: TF536 IDE speed
There was never a problem.
richx
Re: TF536 IDE speed
Post a picture of your 030. As mentioned, you might have a fake "50Mhz". I believe the TF will clock down CPU when accessing chip/slow RAM, which is probably majority of what Super Frog does, whereas Doom would be more heavy on SDRAM running CPU at full clock speed.kulamario wrote: 30 Jun 2020 13:13 When I left super frog for whole night run without problem same frontier working perfect but Doom and Nemac no want
Homer79
Re: TF536 IDE speed
Thanks Ill try this program with my TF536 and see what it does
[/quote]
[/quote]
[/quote]
[/quote]
kulamario
Re: TF536 IDE speed
Bought from this seller www.ebay.co.uk/itm/143326528869
