Getting WFI Working on TF3xx with ESP Module
Re: Getting WFI Working on TF3xx with ESP Module
I strongly recommend using slattach after you flash the ESP module and set your wifi settings from linux/macos.
Higgy
Post by Higgy »
Self-flagellation has taken place :o Mistake - schoolboy error downloading SLIP firmware. Now corrected. I was flashing cr*p before.
Next issue. My SSID is in capitals. This seemed to give DCTelnet a 'computer says no'. I was not going to change my SSID name so ended up using the other AMIGA telnet program Steven mentioned.
That accepted the implausible situation of having a SSID in capital letters :D (I guess there might be an installation error in DCTelnet, especially when everyone else tells me their SSID is in capitals and set ssid worked ok :oops: )
Any ho. Now I am on the web. Off to download some more 'Klondike card sets' :o ;) Cheeers 8-)
sugar
Post by sugar »
Mid-summer festivities are over so I had a chance to look at the TF360 wifi issue again. I got it to work at 38400 baud which is somewhat less than the 216000 baud the TF330 achieves. I tried different CD32s and CPUs and a bigger stack as well as alternative slip drivers. Perhaps I should try CPU caches or resolder the ESP header as I would imagine this means an issue with interrupts or a high error rate.
sugar wrote: 22 Jun 2020 09:54 Mid-summer festivities are over so I had a chance to look at the TF360 wifi issue again. I got it to work at 38400 baud which is somewhat less than the 216000 baud the TF330 achieves. I tried different CD32s and CPUs and a bigger stack as well as alternative slip drivers. Perhaps I should try CPU caches or resolder the ESP header as I would imagine this means an issue with interrupts or a high error rate.
My 360s all work fine at 115200. I've no intention of trying them with anything else.
sugar
Post by sugar »
terriblefire wrote: 22 Jun 2020 09:58
Yes but my issue is that I can't get the TF360 to run at 115200 nor 57600 but only 38400 or under. The TF330 performance was just for comparison with the same hardware but a different TF.
sugar wrote: 22 Jun 2020 10:09
There is no hardware difference for this part between TF330 and TF360.
sugar
Post by sugar »
terriblefire wrote: 22 Jun 2020 11:32
Actually I was a bit imprecise with this. I can set up a network connection at 115200 and use ping and get network time but wget and Ibrowse freeze quickly at this speed. I'm using the latest Roadshow and a CF from Superduper.
That sounds like maybe a noisy line.. Clean the edge connector contacts and try again?
sugar
Post by sugar »
terriblefire wrote: 29 Jun 2020 19:32 That sounds like maybe a noisy line.. Clean the edge connector contacts and try again?
Gave them a rub and a rinse but didn't seem to change the behaviour. It's kinda quirky since I did a wget on a file that wasn't on aminet and it crashed after getting the 404.
I realized I see CF card access on my screen as dim noise. I guess I should try another CF card and recheck the PSU.
i'm not seeing it myself but im not doing masses with the network connection at the moment.
Users browsing this forum: ClaudeBot, semrush [bot] and 11 guests
