TF534 on A1000
EzdineG
TF534 on A1000
TF534 on A1000
Motherboard Rev: ? w/ daughterboard
CPU: 030 @ 40mhz
FPU: Yes
Fit with Relocator: Yes
Relocator: EzdineG (gerbers here)
AmigaOS: 3.1.4 w/ bestwb 1.1; also 3.1 / classicwb
This post is confirmation that the TF534 works correctly with the Amiga 1000. Tested thoroughly for weeks now using the relocator above. Machine would not post with Kickstart 1.3, possibly due to RAM autoconfig, but works fine >= 3.1.
CPU: 030 @ 40mhz
FPU: Yes
8 Bit Dreams
- Moderator Team
Re: TF534 on A1000
Thanks for this update,
right, will not work under 1.3 for two reasons:
1. Zorro lll isn't working under KS 1.3
2. No scsi.device in rom
kulamario
Re: TF534 on A1000
Have question about Amiga 1000 and TF534
If I swap kick for 3.1 TF534 I'll be working on A1000 without any mods ?
- Admin sponsor
Re: TF534 on A1000
Yeah it should still post... just no ram or ide drive..8 Bit Dreams wrote: 07 Jul 2019 01:44 Thanks for this update,
@EzdineG was the kick1.3 soft kicked? I think the soft kick bootstrapper has incompatibilities with 030 cpu?
EzdineG
Re: TF534 on A1000
No, this was using the hardware mod allowing the use of a physical ROM. 1.3 would get stuck after the first color change before the workbench hand appeared.terriblefire wrote: 28 Jun 2020 21:51 Yeah it should still post... just no ram or ide drive..
Without the mod, both TF530/534 would crash at the bootstrapper as you describe above.
- Admin sponsor
Re: TF534 on A1000
Is that an A1000 specific 1.3? If so i'd try an A500 one just for a laugh.EzdineG wrote: 28 Jun 2020 23:17No, this was using the hardware mod allowing the use of a physical ROM. 1.3 would get stuck after the first color change before the workbench hand appeared.terriblefire wrote: 28 Jun 2020 21:51 Yeah it should still post... just no ram or ide drive..
EzdineG
Re: TF534 on A1000
It was the A500/2000 common 1.3.
That said...
It is possible I was attempting to boot with a version that had the scsi.device hacked in, because I did have that setup booting with the TF530’s IDE.
If you need confirmation, I can try it with a 1.3 masked ROM.
That said...
- Admin sponsor
Re: TF534 on A1000
Its just useful to know if that rom will boot with 030.EzdineG wrote: 28 Jun 2020 23:25 It was the A500/2000 common 1.3.
That said...
EzdineG
Re: TF534 on A1000
I can confirm it does.terriblefire wrote: 28 Jun 2020 23:29Its just useful to know if that rom will boot with 030.EzdineG wrote: 28 Jun 2020 23:25 It was the A500/2000 common 1.3.
That said...
Before the 534, I used 1.3 on the 1000 with the TF530 just fine (even got IDE to work later with the hacked scsi.device ROM.)
- Admin sponsor
Re: TF534 on A1000
Ok good to know. I have one of your ROM boards built for my A1000 but its actually sitting in my H4 at the moment.EzdineG wrote: 28 Jun 2020 23:32I can confirm it does.
Users browsing this forum: ClaudeBot and 21 guests
