Mega STE, explosive boot
fenarinarsa
Post by fenarinarsa »
I had a bad surprise when I booted up my Mega STE this evening...
I tried to remove and replace the SIMMs and it booted, but an hour later it started to crash again.
In addition a few weeks ago I plugged it on a broadcast-grade HD CRT monitor and noticed that the video signal was not stable - it was perfect on my other regular STE. It was kind of "weavy" horizontally.
My guess is I need at least to do a full PSU recap but my experience in soldering counts in only a few hours. Any suggestions? I'm not really sure I can do a correct job even if the guide looks to be really well done.
That and I hope it's not something worse.
Any advice is welcome :)
Re: Mega STE, explosive boot
If you can get some Isopropyl Alcohol wipes, or just the fluid, then that will help clean any contacts up, but a re-cap may be something you should consider anyway.
If it's taking an hour to crash, it may be heat related. Not sure what fans the MSTEs have, worth checking they're running ok if it has them.
rubber_jonnie wrote: 14 Feb 2018 14:13 If it's taking an hour to crash, it may be heat related. Not sure what fans the MSTEs have, worth checking they're running ok if it has them.
Just like all but the very earliest TTs, they have just the PSU fan.
fenarinarsa
It's not heat-related, I just tried to power it on again after one full day of no use and it crashed on boot.
stephen_usher wrote: 14 Feb 2018 19:09
Actually I think the earliest TTs had two fans, the later models only had the PSU fan.
Steve wrote: 15 Feb 2018 03:07
Indeed, that's what I said. :-)
Haha I missed the `but` :)
fenarinarsa wrote: 15 Feb 2018 01:08 It's not heat-related, I just tried to power it on again after one full day of no use and it crashed on boot.
Yep, definitely not a heat problem then. Contacts is a good place to start, may be worth getting a magnifying glass out and having a close look at caps, just in case.
If cleaning the contacts, have you considered a SIMM swap to see if that makes a difference?
