Blowing the dust off some old Ataris. Suggested fixes?
WiseGreasyBastard
Post by WiseGreasyBastard »
I've been tempted by terriblefire's 030 boards :evil:
This means I'm going to be blowing the dust off some old Ataris and powering them up after a very long while being in storage.
Assuming they even survived being laid up; apart from the electrolytics probably needing replacement is there anything else I should be looking at before powering them up?
I've got a few STFMs, a few Mega STs, a pair of Mega STEs and a TT 030 to go through.
WGB
Re: Blowing the dust of some old Ataris. Suggested fixes?
@WiseGreasyBastard - A good place to start is this post https://www.exxosforum.co.uk/forum/viewt ... =17&t=1585
It lists mandatory fixes for our beloved machines.
Yes, at a bare minimum do not turn them on before servicing the PSU :)
I'd agree with @Steve if they haven't been powered on for a long time.
My preference is to hook mine up to a load (I have an ST specific one built using resistors from exxos' store) for first power on if they have been in storage for a long time, and then only once the thing has been inspected and shows no signs of damage.
For long term storage items I'd also consider going straight for a PSU recap.
WiseGreasyBastard
Icky wrote: 17 Jun 2020 07:50 @WiseGreasyBastard - A good place to start is this post https://www.exxosforum.co.uk/forum/viewt ... =17&t=1585
Thanks for the link. That's spot on.
rubber_jonnie wrote: 17 Jun 2020 15:16 I'd agree with @Steve if they haven't been powered on for a long time.
The last time I powered one on was probably 15 years ago. The TT hasn't been powered on for longer than that.
A write up I just came across suggests loading the PSU with resistors for < 30 seconds. Is that just because the resistors get hot or due the the PSU loading?
I've got electronic DC loads I can use to hold the PSU rails at whatever they're spec'd at if anyone has those details?
WGB
Tomswork
Post by Tomswork »
Is the Tt Like the mste with the 5341 psu. There are some nice psu in the us that will fit in the metal frame and are 36usd
Tom
WiseGreasyBastard
Tomswork wrote: 17 Jun 2020 19:43 Is the Tt Like the mste with the 5341 psu. There are some nice psu in the us that will fit in the metal frame and are 36usd
Tom
From memory - I think they are the same, or at least VERY similar.
Do you have a link for the replacement PSUs?
I have a few PicoPSUs that would easily fit in the metal case and run with a power brick. It's another option.
WGB
Tomswork
Re: Blowing the dust off some old Ataris. Suggested fixes?
Post by Tomswork »
https://www.reactivemicro.com/product/u ... er-supply/
This has +5-5+12-12
Nice and compact
Tom
WiseGreasyBastard
That's an open frame medical power supply. There's a good chance something similar available locally.
Thanks for that.
WiseGreasyBastard wrote: 17 Jun 2020 19:01
WGB
I got the resistors from exxos' store and built a load module with a heatsink. I can run it for longer than 30s no problem.
However, if you have an electronic load, that would do very nicely, the PSUs generally have the maximum power details on them so you should be able to work out the load from that.
I think generally it's 5v/3A and 12v/1.6A.
Users browsing this forum: ClaudeBot and 15 guests
