TF536 Bulk Order (Batch 1 Shipped)
8 Bit Dreams
- Moderator Team
Re: TF536 Bulk Order (Batch 1 Closed)
there are 4x 10µF 1206 caps on the board :idea:
C1, C2, C6, C17
C1, C2, C6, C17
- Admin sponsor
Just use the cap dicekatarakt wrote: 14 Jun 2020 12:44 I figured out some bug in the two BOMs.
In the first post Stephen wrote to complete the build "2. 2 x 10uF 1206 Caps.", but both BOMs (Bom_TF536.csv and Bom_TF536_Buffered.csv) there are 10x 10uF 1206 Caps ?! Should be two to complete populated boards ?
katarakt
Sorry to annoy again, i'm ging through the Full BOM...something is wrong here. Text says all 10k ? Can someone please point me to the correct digikey part numbers please?
6 0 CAY16-103J4LF RESCAXE80P320X160-8N RN5, RN6, RN7, RN8, RN9, RN10
Res Thick Film Array 10K Ohm 5% 200ppm/C ISOL Molded 8-Pin 1206(4 X 0603) Convex SMD Paper T/R
2 2K2 CAY16-103J4LF RESCAXE80P320X160-8N RN1, RN4
2 CAY16-222J4LF CAY16-103J4LF RESCAXE80P320X160-8N RN2, RN3
- Admin sponsor
You're looking at the wrong column. Just look at value and ignore device. Value is the left of the ones there and is correct.katarakt wrote: 14 Jun 2020 15:53 Sorry to annoy again, i'm ging through the Full BOM...something is wrong here. Text says all 10k ? Can someone please point me to the correct digikey part numbers please?
Device is the package i used to get the footprint. not the value. Its not editable in eagle.
katarakt
Ok thanks. So:
RN1, RN2, RN3, RN4 are all "RES ARRAY 4 RES 2.2K OHM 1206" (digikey CAY16-222J4LFCT-ND) ?
RN5, RN6, RN7, RN8, RN9, RN10 are all zero ohm (bridge instead of buffer as i know)? .... i can't find the part on digikey, there are so many similar ones :?
8 Bit Dreams
- Moderator Team
0 Ohm RNs im using are here:
https://www.digikey.de/products/de?keywords=Y9000CT-ND
You need them only if IDE is unbuffered, otherwise left unpopulated!
RN1, RN4 - 4k7
RN2, RN3 - 2k2
PS
if someone want to sell his unpopulated boards - please PN me, im out of boards...
RN1, RN4 - 4k7
RN2, RN3 - 2k2
PS
katarakt
Thanks 8 Bit Dreams !
Are you sure? Full BOM says RN1, RN4 = 2K2 !
Value RN2, RN3 is missing in the full BOM.
8 Bit Dreams
- Moderator Team
yes, im pretty sure, have built 20 of them :lol: :P
katarakt
Ok, if this as you say is correct:
RN1, RN4 - 4k7
RN2, RN3 - 2k2
...the full BOM here in post 1 from steven is definitely wrong.
On the populated boards RN1-RN4 have all "222" printed on them ....so should be the same :?:
Steven, can you check this please?
RN1, RN4 - 4k7
RN2, RN3 - 2k2
Users browsing this forum: ClaudeBot, semrush [bot] and 9 guests
