I finally got hold of a real UV-C erasing bulb, after buying one fake and getting another one cancelled due to postal service being withdrawn from the seller in China.
So I was able to burn TOS 1.04 and 2.06 onto the two halves of my ROM chip, but only 1.04 works for me on the H4. I read the contents of the chip back and compared the data and it's a match to the TOS 2.06 binary that I downloaded from http://www.avtandil.narod.ru/tose.html (tos206uk.zip).
Is there anything you need to know for this version of TOS to boot on the H4? I burned it at address 262,144 (0x40000) and it's not byte-swapped (it's the same byte order as 104, which works). I just get a completely black screen on startup.
Smonson's slow H4 build
Smonson
derkom
Re: Smonson's slow H4 build
TOS 2.06 will not boot on the H4 without a 2.06 decoder for example on the beta IDE board.
Smonson
Aha! That's exactly what I needed to know, thanks!
I have done some dedicated 206 decoder boards for such things as well :)
Smonson
It makes sense in retrospect, I should have realised ahead of time. Since the STFM places TOS at 0xfc0000 and 0xffxxxx is, I think, all reserved for memory-mapped peripherals. I can easily live without TOS 2.06 for the time being.
PaulJ
@Smonson , you should consider giving @cmorley's eprom emulator a try. It still requires a decode that provides the $0, $fc0000, and $e00000 as the eprom but its easier to use, holds 8 256k images and you don't need to pull the eprom out, burn it, and re-install.. then repeat if something went wrong. I just leave the USB cable connected so I can blast a new image and switch to it in seconds. I program sections that are not the selected image while the Atari is on and just press the reset. When you program one of 8 slots you can choose partial burn, byte swap, and a number of other things. Its a lot more convienient than using eproms especially if you working on a TOS code.
Smonson
Thanks, I'll keep it in mind. I prefer to make my own stuff though. It seems like overkill for what I need anyway.PaulJ wrote: 13 Jun 2020 15:02 @Smonson , you should consider giving @cmorley's eprom emulator a try.
troed
You can create your own TOS E00000 decoder with a GAL16V8 and some old schematics IIRC. I think I have those somewhere.
/Troed
/Troed
mfro
My understanding is that 13.0pl1 is the latest version that supports CII?Smonson wrote: 13 May 2020 11:05... Unfortunately Quartus 12 no longer runs on the latest Ubuntu and I don't have enough laptop disk space to install another OS so that's a bummer, I will be constantly walking between my PC and the other room to try stuff. A very annoying decision on Intel's part for taking Cyclone-II support out of Quartus at version 12.1.
I'm not on the absolute latest (using Debian) but for now, I always got Quartus to work with some fiddling. Last time I installed Ubuntu 12 in a KVM, installed Quartus there, verified which shared libraries it drew (using ldd) and copied all of them into the Quartus bin directory of the native machine which worked fine.
Smonson
Unfortunately 12.0sp2 is the last version for cyclone-2. It's a 32-bit application and that's the reason why the new Ubuntu can't run it. I can still run it on Windows actually - I didn't even think about that when I first mentioned it - probably because using Windows for software development is even more inconvenient than walking from room to room ;)
Eventually I'll get a bigger SSD for my laptop, then I can run it in a VM.
