Robson’s
Re: Robson’s
The DMA fix board arrived thanks to @DoG and it's now installed.
I've also done the 1.44 mod and installed the gotek as described here:
https://exxosforum.co.uk/forum/viewtopic.php?f=78&t=2551
The bootloader comes on but after displaying the fw version I get the Error: LBA change Test Failed! Write Issue? message.
It works when I set everything back to default.
Any ideas?
Any ideas?
Re: Robson’s
I don't believe that this issue was resolved and might be worth asking on the FF Github pages.
I don't use the HxC Autoboot HFE tool. Instead, I use and OLED and then use the Gotek buttons to load disk images.
Re: Robson’s
IDE is now working. The DMA fix slightly pushes the DOM up. I'll lower it at some point.
Re: Robson’s
Nice. Another H4 and IDE working
Re: Robson’s
No need. You were born with one.
Re: Robson’s
Board nr2 that I bought from @Velociraptor.
I was going for it, this is all built today. Only few things left but run out of sockets so will fully complete the board when they're here.
Re: Robson’s
Pretty impresses amount of stuff added in just a day!
Re: Robson’s
After a little bit of sizzling that's cured with IPA bath + drying Board Nr2 is alive.
