Atari ST keyboard interface.
arkadiusz.makarenko
Moderator Team
Moderator Team
Re: Atari ST keyboard interface.
Post by arkadiusz.makarenko »
Managed to make USB mouse working inTOS.
~ Stanislaw Lem
Post by JezC »
Nice - which Nucleo board is that one?
arkadiusz.makarenko
Moderator Team
Moderator Team
Nucleo F722ZE.
Great for dev for new line of budget stm32 f72x/f73x series.
~ Stanislaw Lem
Post by JezC »
Yes, we're using the H750 in some of our products...a bit pricier but still pretty low cost for the performance!
arkadiusz.makarenko
Moderator Team
Moderator Team
JezC wrote: Sun May 24, 2020 11:03 pm Yes, we're using the H750 in some of our products...a bit pricier but still pretty low cost for the performance!
What is main advantage of H series?
~ Stanislaw Lem
Post by JezC »
The main one is speed - the H7 can clock up to 480MHz compared to 216MHz for F7.
Also, some H7 parts also have a Cortex M4 core as well as the M7 core.
There are also some options for (value line) parts with very little internal Flash but lots of internal RAM & the ability to execute code from external serial memory - the H750 has 128k Flash but 1M RAM for example & that makes the higher performance available at a much lower price for some applications.
The newer ADCs are also giving much greater resolution (14 bit compared to 12 bit IIRC) even at high sample rates.
There is far more than that in the mix as well, but that should give you some indication I hope.
arkadiusz.makarenko
Moderator Team
Moderator Team
JezC wrote: Mon May 25, 2020 4:52 pm The main one is speed - the H7 can clock up to 480MHz compared to 216MHz for F7.
Thank you. This saves me day of datasheets comparison.
Value H line are cheaper than expected. Maybe will play with ultrasatan port :D
~ Stanislaw Lem
Post by JezC »
You're most welcome.
Yes, we've used the earlier STM32 F1/2/4 parts before but the price of the value line for H7 is much more competitive.
It should have the raw processing to handle pretty much anything (I'm thinking of USB host interface for keyboard, mouse, even Ethernet & pen drive & possibly even SD Card interface may be possible here). 8-)
If only I had the time to tackle something like that... :(
I'll be following your progress with great interest! :thumbup:
arkadiusz.makarenko
Moderator Team
Moderator Team
Ok. I managed to get keyboard presses to work, but still depress doesn't work. And I need reset routine to work as well.
Ps.
Is there a software which would help keyboard testing?
~ Stanislaw Lem
The diagnostic cart has a keyboard test in it I believe.
