TF536 Bulk Order (Batch 1 Shipped)
68030 + SDRAM + IDE
Re: TF536 Bulk Order (Batch 1 Closed)
@Mario_PL and others with deleted posts.
Your posts were removed because you keep asking for boards when none are available. Terriblefire has already said as much a number of times in this thread.
There will be another batch of boards im sure but until then, asking for one when none are available will result in the deletion of that post.
Your patience will be rewarded in batch two I suspect.
Hope that helps.
philbo34
Post by philbo34 »
1 assembled if poss
other ill take what ever is available ,thanks
mixinu
Post by mixinu »
terriblefire wrote: Wed May 20, 2020 9:06 am Ok guys.. Please dont take offence but i am going to delete all the requests post the closure of the batch. There will be another batch but it will be after a small TF360 run.
No offence taken. Already waiting for batch 2 :mrgreen:
JoeFloyd
Post by JoeFloyd »
My preference is for the assembled board, but the allocation of boards is at your discretion. I will accept what is offered.
Joe (On the list for 2)
matt020
Post by matt020 »
mixinu wrote: Fri May 22, 2020 5:49 am No offence taken. Already waiting for batch 2 :mrgreen:
Seriously. Stop it.
madness77
Post by madness77 »
Great, someone bought all the sockets...
8 Bit Dreams
Moderator Team
Moderator Team
Post by 8 Bit Dreams »
madness77 wrote: Fri May 22, 2020 1:18 pm Great, someone bought all the sockets...
Don't worry, they will restock them, it's a reliable seller for last three years 😉
marioska
Post by marioska »
I will accept what is offered also.
Apologies to all i really should not have gone for bare boards. It was just because the order process was so frustrating.
Danoo
Post by Danoo »
In another thread someone mentioned that they were constructing PGA sockets out of female pin strip.
(I pretty sure the pitch on the socket is 2.54mm but you would need to verify will measure later)
Here is a supplier I use for 2.54mm pitch female pin strip, I am sure there will be plenty more
https://www.ebay.com.au/itm/2-54mm-Pin- ... 2749.l2649
Return to “TF536”
