TF536 Bulk Order (Batch 1 Shipped)
- Admin sponsor
Re: TF536 Bulk Order (Batch 1 Closed)
Ok guys.. Please dont take offence but i am going to delete all the requests post the closure of the batch. There will be another batch but it will be after a small TF360 run.
In terms of the allocation of with/without passives...
There are 89 with passives (board house said they had one board that didnt make the cut) and 60 without passives available.
8 Bit Dreams is taking 20 without passives so that leaves 89 + 40 from the original run.
Are there volunteers who would prefer blanks? Otherwise i'll allocate a 2 and 1 policy and adjust the price. If you ordered a single you'll get with passives unless you specify otherwise.
Dont ask about the spares. They are there to cover losses in the post.
go0se
I'll take 9 blanks and one with passives for comparison if that's ok?... just to see what I'm missing :)
8 Bit Dreams
- Moderator Team
:goodpost: Thank You for update :goodpost:
PS
Would like to take part in TF360 testing too, if possible ☺
PS
- Admin sponsor
Perfect. So thats 31 blanks to allocate out.. any takers?go0se wrote: 20 May 2020 09:35 I'll take 9 blanks and one with passives for comparison if that's ok?... just to see what I'm missing :)
@terriblefire 3 of each is fine by me, so I can build up the 3 I need quickly, others I can take my time with etc.
BTW, you had mentioned in another thread about possibly only needing a 144 instead of the 288s for the ST version. Just wondered if you thought that might be the case as I've got a couple of 144s left as well.
- Admin sponsor
The current ST firmware will fit in the 144. However I wanted to look at doing an ST man in the middle attack on whatever tells the Atari there is an interrupt pending from the IDE Drive. That will need 288.PhilC wrote: 20 May 2020 14:17 @terriblefire 3 of each is fine by me, so I can build up the 3 I need quickly, others I can take my time with etc.
Cool, makes sense to me. thanks.
- Admin sponsor
So 31 bare pcbs allocated. Another 20 to go.
Any takers?
Any takers?
LADmachining
I was last in the queue, so don't mind what I get. Whatever is left...
8 Bit Dreams
- Moderator Team
Will be happy to take more than 20 that ive preordered ;)
Users browsing this forum: ClaudeBot, gpt [bot] and 3 guests
