exxos blog - random goings on
ube
Post by ube »
However. We could emulate the 555 in the ATTiny, making it smaller.
master of the bare pcb
I was looking at this one ..
https://www.kurtzersa.com/electronics-p ... robot.html
I thought as this one has PC software, it will be more suitable for my needs and be cheaper...But nope...£45-55K :shock: :shock:
ube wrote: 20 May 2020 12:47 However. We could emulate the 555 in the ATTiny, making it smaller.
Never thought about that! do a one second reset time on power up reliably though ?
ube
Post by ube »
exxos wrote: 20 May 2020 12:49 Never thought about that! do a one second reset time on power up reliably though ?
There's only one way to find out, right? :D
ube wrote: 20 May 2020 13:44 There's only one way to find out, right? :D
Mission for you then ;)
I have also been looking into pick and place machines...
Again these things are pretty expensive... While changing reels would be incredibly annoying... Most of the parts I use on my projects I always try to use similar values and types so I don't have to keep buying so many different parts all the time.So such a machine in my case could be loaded up with generic parts and do probably all the SMT parts I use on most projects.
ube
Post by ube »
exxos wrote: 20 May 2020 13:51
Looking at the circuit (and using online calculators) it seems like the function is to keep RST low for 0.29s after the button has been released, right?
So a big enough pull down on the reset line and then setting a pin to high after a timer has run out ought to do it?
ube wrote: 20 May 2020 14:37 Looking at the circuit (and using online calculators) it seems like the function is to keep RST low for 0.29s after the button has been released, right?
Yeah, but in order not to cause problems, the timer should keep the line low for 1 second ideally.
ube
Post by ube »
I’ll knock something together.
In the mix of things I have been experimenting with my own "PLCC PLUG"...
Users browsing this forum: Bing [Bot], ClaudeBot, Marcopolomint1, mikro, semrush [bot] and 18 guests
