This should work out of the box with Genesis and maybe AmiTCP as Genesis is just a GUI for it.
I think that it could be tinkered to work with Roadshow, as it is just a backport of OS4 tcp stack. I think that I used this http://aminet.net/package/comm/net/NetFS but there is now also this http://aminet.net/package/comm/net/NetFS-revised
I have Roadshow licenses, but I decided to revert back to Genesis, mostly because of nice GUI.
Amiga to Amiga networking over tcp/ip
- Admin sponsor
Re: Amiga to Amiga networking over tcp/ip
I use Roadshow for the same reason... because the others have a GUI. I dont see why a TCP/IP stack needs one.utri007 wrote: 18 May 2020 12:52 This should work out of the box with Genesis and maybe AmiTCP as Genesis is just a GUI for it.
matt020
I continue to get "unknown error code" and I am using Genesis on both Amiga's. I suspect something would have to be running and listening on the other Amiga?
- Admin sponsor
Appears that that genesis sets up NetFS. If you are using an ESP module you may need to find out what port that runs on and setup the portmap in the esp routermatt020 wrote: 19 May 2020 00:47 I continue to get "unknown error code" and I am using Genesis on both Amiga's. I suspect something would have to be running and listening on the other Amiga?
matt020
I got it working. I'm using Genesis.
The video in the posts above helped, as it showed that the "Access" must be set to allow any IP to access the Amiga.
But you also have to enable AmigaNetFS in the "Services" tab, there is a tick box that needs to be selected.
Then, it just worked using the NetMount command.
So, yes, there has to be a service running on the Amiga hosting the drives. My CD32 with ESP8266 is able to mount drives from other Amigas in the house, but I cant map the CD32's drives and this is because I need to set the PORTMAP setting as Stephen suggested on a previous post. To do that, the port number is needed....
- Admin sponsor
Sweet. Nice work.
matt020
A quick bit of Google work, it appears Netfs uses TCP port 2500.
I will test this on the CD32 over the next day or two in between work.
matt020
Confirmed. Amiga Netfs does indeed use port 2500.
I now have CD32 drives mapped on my A4000 (as CD32work: and CD32whdload:), I can view them in shell, DirOpus, no problems.
Looks like Netfs is available on Aminet. Genesis simply launches "netfs-server" in the background when it establishes a connection.
supaduper
Execellent Matt , CD32 networked in 2020, who`d have thunk it :D
Amifun
Hello
Sorry for using this old thread, though perhaps you might shed some lights how to get online, hardware/software side?
As I just got my cdf32 alive again and am awaiting my tf330:)
thanks
Kai, Norway
thanks
Kai, Norway
