TT030 CA401146-001 REV.H
TT motherboards.
krupkaj
Post by krupkaj »
Here are 2 versions of TT
Neffers
Re: TT030
Post by Neffers »
Add CA401146-001 REV.H in your title. It may help somebody some day 8-) There's nothing I can see on the first board but if you find info, add that too.
Resident idiot. (Qualified, got a Diploma and everything)
Re: TT030 CA401146-001 REV.H
Title updated with part no/rev. :D
Maeke
Post by Maeke »
first one is ca400770, it's written just besides what seems to be the cpu.
Edit; ah i see the same number on the second board, so it probably means nothing much
If i take too long to reply, sorry my cat is sleeping on my laps.
Your REV.H board has a lot of wires running around the bottom IC's and to the CPU. I wonder what those are as my REV.H doesn't have these.
vattari
Post by vattari »
:dualthumbup: :dualthumbup: :dualthumbup:
Thanks for this post. I have a TT that needs some ICs replaced and this detailed enough to show what I need to do
krupkaj
Post by krupkaj »
it is great it helped you
Found it! - https://www.dev-docs.org/docs/htm/search.php?find=_4 document named TT030 Rev B1 and D Board Rework Schematic
Has anyone undertaken this work as the schematics in the doc are a little faded? I would like to have a go but would appreciate any pointers.
Atarian Computing
Post by Atarian Computing »
Return to “TT”
