TF536 Rev 2 Design Complete (all gone)
LADmachining
Re: TF536 Rev 2 Design Complete (all gone)
Well, I don't have a spare CPLD, as my one had the same bad packaging you had and all of the corner pins are bent. :x
- Admin sponsor
Did you get a refund from RS?LADmachining wrote: 09 May 2020 12:01 Well, I don't have a spare CPLD, as my one had the same bad packaging you had and all of the corner pins are bent. :x
LADmachining
Will have to contact them Monday, hopefully they can send me another.terriblefire wrote: 09 May 2020 12:04Did you get a refund from RS?LADmachining wrote: 09 May 2020 12:01 Well, I don't have a spare CPLD, as my one had the same bad packaging you had and all of the corner pins are bent. :x
- Admin sponsor
You can do it automatically via the web interface.. Just go to returns.LADmachining wrote: 09 May 2020 12:29Will have to contact them Monday, hopefully they can send me another.
- Admin sponsor
Has anyone tested the rev2 in an ST?
I've just tried my rev 1 and rev 2 with identical firmware code and the rev 1 is fine and the rev 2 sulks...
I've had my Rev 2 running TOS 2.06 but its a bit hit and miss, I get 8 bombs sometimes and boots the next.terriblefire wrote: 09 May 2020 15:09 Has anyone tested the rev2 in an ST?
I've got as far as running Gembench with it a few times (slow results as the firmware wants tweaking as you know)
Managed to burn the latest EmuTos to rom and it boots to desktop fine with that.
I'm using one of exxos's ide boards as the rom decocder tho, so not tested the ide interfaceon
Edit:
won't run Gembench though as I get kernel errors etc and of course this IDE board is probably confusing the hell out of it.
Edit:
- Admin sponsor
I'm struggling to get this ST to work at all to be fair... :/PhilC wrote: 09 May 2020 15:56 Managed to burn the latest EmuTos to rom and it boots to desktop fine with that.
Edit:
I'll try and plug it into an original ST and see how it goes
- Admin sponsor
I've got an ST firmware if you want to test it
