TF536 Rev 2 Design Complete (all gone)
68030 + SDRAM + IDE
Re: TF536 Rev 2 Design Complete (all gone)
agranlund wrote: Thu May 07, 2020 2:40 pm I think that was it really, pretty much just IDE and the RAM location :)
As far as I know, you should be able to keep going north to cover all the memory.
At least EmuTos starts reading at 0x01000000 and just keeps going until it hits a bus error in order to figure out how much of it there is.
(A quick glance at the Atari TOS sources suggests it does the same but it's all uncommented asm so I wouldn't bet my life on it :D)
Ok.
I think this covers the basic 64Mb version ...
 assign ram_decode = ({A[31:24]} != {8'h01}) & ({A[31:25]} != {7'd1}) & ({A[31:26]} != {6'd1});
Which covers 0001, 001x, 01xx
Might only give 48Mb... good for a start.
agranlund wrote: Thu May 07, 2020 2:40 pm I did something in bus_delay.v to get it playing nice with the Blitter but I'm guessing this is irrelevant in the new design anyway.
I think thats covered.
agranlund wrote: Thu May 07, 2020 2:40 pm Oh, and Atari TOS requires the IDE IRQ in order to work, we usually solder it to pin10 of the ASCI port as it's very easy to get to.
I exposed that signal to the INT2 pad on the TF534 and ifdef'd out the Amiga INT2 related things.
But EmuTOS doesn't seem to care and I think that one will work regardless.
I don't really use Atari TOS much anymore, EmuTOS is so much better and requires less "convincing" to work with modified machines :)
Now this is kinda interesting because the TF536 can do IRQ injection and patch up accesses to anything that reports them. It'd be interesting to fix this.
richx
Post by richx »
Are you including support for 128MB in this firmware mentioned a few weeks ago? Happy with 64MB but would be nice to use same chips for multiple boards, I believe the pinouts are the same, just more banks. If you're already gauging interest for the next batch, I would like 2x :)
richx wrote: Thu May 07, 2020 5:20 pm Are you including support for 128MB in this firmware mentioned a few weeks ago? Happy with 64MB but would be nice to use same chips for multiple boards, I believe the pinouts are the same, just more banks. If you're already gauging interest for the next batch, I would like 2x :)
I'll add the firmware support but i''m not gonna test it personally.
Subzero79
Post by Subzero79 »
Just finish to solder
Just awaiting 2.2 rns
Homer79
Post by Homer79 »
Hi, if your ordering 100 can you put me down for 5 boards please.
Regards
AEV80
Post by AEV80 »
I'd like to be grab a few boards too if possible.
PaulJ_2.0
Post by PaulJ_2.0 »
I will take 10-20 (depending on availability of course)
Ok lets keep this thread clean for issues etc and I'll start a new one for the PCB order. I'll need to work out pricing for multiples and I may need a deposit for a 10+ board order. Sound fair? If i do it this way everyone gets what they want. I'll also fix the 2 missing RNs in the assembly order this time.
PaulJ_2.0
Post by PaulJ_2.0 »
terriblefire wrote: Fri May 08, 2020 8:50 am I may need a deposit for a 10+ board order. Sound fair?
I doubt anyone would have a problem with that.
Subzero79
Post by Subzero79 »
Beetween gng and 3.3 volts i measure 1.1 ohm is normal
Removed all ics exept cpld and measures 1 ohm or is board defect?
Unsolder all parts pcb defective short beetween gnd and 3.3
@ terriblefire need a new one
Return to “TF536”
