I have recently bought a non working ZX Spectrum 128 (toast rack) and I am struggling with the repair since. Maybe someone here has repair experience with these and has some ideas how to proceed...
It was pretty much dead when it arrived, but after changing the 5V regulator and TR4/TR5 it showed some life signs. To be safe I swapped all electrolytic capacitors as well.
From the symptoms it looked like some RAM chips were gone, to help in locating these I used the diagnostic ROM by Retroleum. It signaled a couple of malicious RAMs and I swapped them as well. It all worked well until I came to IC10 that should be responsible for Bit 3. I swapped it and nothing changed. On every test cycle I run it always shows this IC as faulty. Of course I swapped with (several) other chips, double checked the soldering even swapped the socket again just to be sure.
I checked continuity on the adress lines and looked at the data line, it all looks okay to me. Voltages are fine as well.
Two additional strange things:
1. Upper Ram tests completely fine.
2. a different diagnostic ROM shows bits 7,6,5,4 faulty... WTF?
The screen is garbled and barely readable, sound output looks fine. The ROM reacts as it should, but nevertheless I swapped the CPU, just to be safe. No change.
Right now I have swapped and socketed all RAM chips, the CPU and the ROM. All caps are replaced, as well as TR4, TR5 and the 7805.
What puzzles me, is that upper RAM works fine, only lower RAM seems to be faulty. When I look at the schematic, data busses are identical, so these are most likely not the fault. Has to be addressing then, and there seem to be two chips involved: the ZX8401 multiplexer and the ULA.
Both are hard to come by, so I hesitate to simply swap them without being sure.
So if anyone here has some ideas about this, it would be a great help :)
Speccy repair
IngoQ
Speccy repair
Ingo :geek:
Re: Speccy repair
All I can suggest is contacting Gadget UK... He does the hell of a lot of retro computer repairs.. So is probably the best person to ask about this sort of thing..
https://www.youtube.com/user/GadgetUK164/videos
I did mention this forum to a while ago in fact..
IngoQ
Re: Speccy repair
Thanks, I know his videos, although I sometimes struggle in understanding him ;)
Ingo :geek:
Re: Speccy repair
If you're going to send it away definitely use Mutant Catapillar:
http://www.mutant-caterpillar.co.uk/sho ... ts_id=3481
As for the problem, check all the resistors! I had a similar problem with my +128K and one of the problems was a resistor which looked OK but crumbled as soon as it was touched.
IngoQ
Re: Speccy repair
Thanks Stephen, I took your post as a challenge to recheck the mainboard very carefully for undiscovered faults.
When doing this I re-checked the address lines, and what can I say... found a nicked trace on A0 well hidden under a ceramic cap, separating IC10,11,12 and 13.
Lesson learned: Sometimes continuity check can be be wrong... supposedly when there is still charge in some caps :roll:
Now let's see why the AY is silent...
Ingo :geek:
IngoQ
Re: Speccy repair
Finally working :) AY was okay, just very weak. Applied a stereo upgrade with better mixing and separate output and now it sounds fine :)
And here it is in all its glory:
Ingo :geek:
Re: Speccy repair
Nice :) A friend when I was at school had a speccy.. Remember playing "heart broken" a lot back then.. think it was the only game I could get to load :lol:
Might have played bombjack as well, though ST version was better ;)
DrF
Re: Speccy repair
A proper Spectrum game :
https://en.wikipedia.org/wiki/Chaos:_Th ... of_Wizards
Absolutely blew our little minds spent hours on it, our copy was off a cover tape, I recall something about Ninja Hamsters too.
We had Amiga/ST versions which I think we're unofficial and well crap :lol:
IngoQ
Re: Speccy repair
Same thing with the Acorn 3010/3020 which is still on my wishlist: Almost none available here in Germany, and only rarely available in GB. Most likely due to the onboard-battery. And they are pricey. And for some reason shipping costs from UK to Germany are quite hefty, which makes buying in UK often not that attractive... but that might as well be a question of how desperate I get ;)
Interestingly the ZX Spectrum 128 shares one detail with the STs: It has the same soundchip (AY-3-8910) ;)
Speccys were not that common here in Germany, this was pretty much C64-land back then. There were some although, but obtaining one now is not easy. Especially the toast rack, which was the last model made by Sinclair, before Amstrad took over is usually only available in GB, and quite pricey. So I am glad I finally got one, even if I had to repair it.
Thanks, I still have to discover the Speccys software-world. I just had a glimpse at some things that were on the DivMMC. The graphics abilities were a lot weaker compared to other 8-Bit machines of that time, but that is part of the charm of that device and I really like it.DrF wrote: 21 Jan 2018 21:08 A proper Spectrum game :
Ingo :geek:
Re: Speccy repair
Yeah, once you get over 2KG now, prices shoot up from like £15 to £60 :roll:IngoQ wrote: 22 Jan 2018 09:13 And for some reason shipping costs from UK to Germany are quite hefty, which makes buying in UK often not that attractive... but that might as well be a question of how desperate I get ;)
Nice :) A lot of the motherboards I repaired in my old job used to be Z80 based, most had the same sound chip as well.IngoQ wrote: 22 Jan 2018 09:13 Interestingly the ZX Spectrum 128 shares one detail with the STs: It has the same soundchip (AY-3-8910) ;)
If you ever see/look at older fruit machines, you can hear the sounds the reels make when spinning.. they sound "ST like" basically because they are and use the same sound chip :)
Hard to exactly remember, but if you google "maygay m1b board" or "project board pc92" then you get the idea of the stuff I used to work on :)
