Module ESP8266 without TF on Amiga
Re: Module ESP8266 without TF on Amiga
kulamario wrote: 18 Apr 2020 13:15 I'll check everything this when I come back from work
But I have question
This slip router working on same rules like plipbox ?
I just want tell I have plipbox in home and this plipbox no run maybe is real my modem is not good for this ?
I fight with plipbox for few days and no success
I have modem F2000
Internet from eir.ie
Another thing maybe my ports in amiga is faulty
Is possible to check ports amiga via some terminal ?
No is NOTHING like plipbox. its a complete router and the slip.device looks exactly like a sana device. No dialup scripts nothing. Its plug and play.
ed_dream
Post by ed_dream »
I am find ttl to serial converter.
Maybe this help to you.
https://m.aliexpress.ru/item/3295699649 ... 567&is_c=Y
kulamario
Post by kulamario »
Today I had some free time and I did the whole process again including downloading the firmware and best of all before disconnecting the ESP8266 from a Linux PC, ping was on 192.168.240.1
I disconnected ESP from the computer and connected to the power supply
Unfortunately, there is nothing answered from 192.168.240.1
as I understand after turning esp8266 on the power supply and login to WiFi should I get something ping?
ESP8266 is logged in to the router of course
And now I cant even connect to
telnet 192.168.240.1 7777
theq
Post by theq »
Try telnet to 192.168.1.2 7777 (the IP it has gotten pr photo)
To clearify: 192.168.240.1 is only accessible from the serial side of the ESP.
kulamario
Post by kulamario »
Nothing happened
kulamario
Post by kulamario »
But when I write
telnet 192.168.1.2 7777
I have connection
As well ping go but on address 192.168.1.2
OK if this isnt working for you why dont you slattach back to it with baud rate 38400 as i suggested?
kulamario
Post by kulamario »
I setup on 38400 but as well working on 9600
But now is 38400 ping working
But why is on 192.168.1.2
kulamario
Post by kulamario »
Should I not change address here ?
kulamario wrote: 19 Apr 2020 21:51 I not should change address here ?
Why are you setting the bitrate to 38400? Set it everywhere to 9600 and leave the IP settings alone.
EDIT: Your issue is either hardware or that the A500 cannot handle 38400 baud with workbench running.
