Module ESP8266 without TF on Amiga
kulamario
Re: Module ESP8266 without TF on Amiga
U mean this RS232 to TTL converter?
ESP8266 working definitely
- Admin sponsor
Yes. Test that then drop the baud rate to 19200 if it still doesnt work.
To change the baud rate You'll need to edit envarc:sana2/slip0.config and then also slattach again at 38400 and issue a set bitate commands, save, reset.
kulamario
Where is this folder in RAM Disk?You'll need to edit envarc:sana2/slip0.config
If is this one there is setup
serial.device 0 115200 192.168.240.2so again connect to linux ?and then also slattach again at 38400 and issue a set bitate commands, save, reset.
- Admin sponsor
OK STOPkulamario wrote: 17 Apr 2020 19:39Where is this folder in RAM Disk?You'll need to edit envarc:sana2/slip0.config
If is this one there is setupCode: Select all
Edit that in ENVARC: not RAM:ENV
Set the 115200 to 38400 then Reboot and try again.
That value in ENVARC must match the bitrate you set in the ESP.
- Admin sponsor
One last thing... now that you have the ESP up on your LAN you can telnet from your LAN on port 7777 to it if you can find it. Your router may have a homepage that lists it?
Mine appears as ESP_04F1DB for example.
kulamario
Edit that in ENVARC
Nothing change
Nothing change
kulamario
Yes my esp8266 is login to network I see this in what devices is connected to router
But how to check in telnet ?
U mean from linux ?
U mean from linux ?
sudo telnet 192.168.240.1-
- Admin sponsor
No whatever its IP is on the lan... telnet from your PC to it on port 7777.kulamario wrote: 17 Apr 2020 20:29 Yes my esp8266 is login to network I see this in what devices is connected to router
U mean from linux ?Code: Select all
You need to take it from here. Its your hardware.
- Admin sponsor
The value in ENVARC:sana2/slip0.config must match the bitrate set in the ESP module.
If you want to be lazy edit the install_script and replace 115200 with your desired bitrate and rerun it.
TBH i would set it to 9600 both sides to start with and get it going at that speed first.
If you know what your ESP router is currently set to then you can change it by
I'm not sure what actual speed you will get out of an A500 serial port. 9600 should be a safe starting point.
EDIT: You also need to reboot after editing the ENVARC settings.
sudo slattach -p slip -s BAUD_RATE /dev/ttyUSB0&
kulamario
I'll check everything this when I come back from work
But I have question
This slip router working on same rules like plipbox ?
I just want tell I have plipbox in home and this plipbox no run maybe is real my modem is not good for this ?
I fight with plipbox for few days and no success
I have modem F2000
Internet from eir.ie
Another thing maybe my ports in amiga is faulty
Is possible to check ports amiga via some terminal ?
But I have question
I have modem F2000
