Did your board arrive?arkadiusz.makarenko wrote: Thu Apr 16, 2020 8:31 pm... weird I had those set up like this by default.terriblefire wrote: Wed Apr 08, 2020 8:44 pm Got it.. needed to set these settings in ST Link Utility
- Admin sponsor
- arkadiusz.makarenko
- Moderator Team
Yes, It did. I sent you PM.terriblefire wrote: Thu Apr 16, 2020 8:51 pmDid your board arrive?arkadiusz.makarenko wrote: Thu Apr 16, 2020 8:31 pm
I have issues with USB FS init config at the moment. HS seems to init all right.
I will have a look at this this weekend.
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
Thats great I couldn't get the board to boot very far.arkadiusz.makarenko wrote: Thu Apr 16, 2020 9:05 pmYes, It did. I sent you PM.
- Moderator Team
I managed to configure clocks on this chip in a way that they allow booting to main.terriblefire wrote: Thu Apr 16, 2020 9:12 pmThats great I couldn't get the board to boot very far.arkadiusz.makarenko wrote: Thu Apr 16, 2020 9:05 pm
Those at this point only for USB and arm itself, need to have a look what else needs to be set up.
Clock resolver not always do the great job unfortunately.
But still something is not 100% right.
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
Yeah even with the board on the bench, erased CPLD i still have an issue but i cannot say what, It cant be the rest of the circuit as there isnt anything attached.arkadiusz.makarenko wrote: Sat Apr 18, 2020 8:21 pmI managed to configure clocks on this chip in a way that they allow booting to main.
- Moderator Team
I managed to set up USB FS to a point when it can detect something, and then it goes to HardFault for no reason with freshly generated project.
Error is either undefined instruction or something else quite weird. Faults are not consistent either.
My bet would be on initial configuration of this chip, but can't exactly point what.
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
My bet would be power, clocks or config. I cant see what i could have screwed up on the circuit but i'm happy to fix anything we see is screwed. .arkadiusz.makarenko wrote: Sat Apr 18, 2020 10:26 pm I managed to set up USB FS to a point when it can detect something, and then it goes to HardFault for no reason with freshly generated project.
- Moderator Team
I can see the same issues on HID2AMI with f722, so circuit most likely is all right. I didn't install cpld, I am on bare boards just now.terriblefire wrote: Sat Apr 18, 2020 10:37 pmMy bet would be power, clocks or config. I cant see what i could have screwed up on the circuit but i'm happy to fix anything we see is screwed. .arkadiusz.makarenko wrote: Sat Apr 18, 2020 10:26 pm I managed to set up USB FS to a point when it can detect something, and then it goes to HardFault for no reason with freshly generated project.
I don't have oscilloscope, is everything all right with 8Mhz oscillator?
EDIT.
My MPU crashes on different points. Sometimes even get to HID descriptors, so very far in USB enumeration, and I can see that USB pipes are set. So it even managed to read some data from USB.
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
I honestly dont know. Do we need to change the crystal for something else? ANything in the docs?arkadiusz.makarenko wrote: Sat Apr 18, 2020 11:45 pm I can see the same issues on HID2AMI with f722, so circuit most likely is all right. I didn't install cpld, I am on bare boards just now.
- Admin sponsor
Worth noting...
Can you use the internal 16Mhz?Clock, reset and supply management
– 1.7 V to 3.6 V application supply and I/Os
– POR, PDR, PVD and BOR
– Dedicated USB power
– 4-to-26 MHz crystal oscillator
– Internal 16 MHz factory-trimmed RC (1%
accuracy)
– 32 kHz oscillator for RTC with calibration
– Internal 32 kHz RC with calibration
