Getting WFI Working on TF3xx with ESP Module
Re: Drivers for ESP modules
@theq does it actually work ok at full speed? 115200?
theq
Post by theq »
terriblefire wrote: Fri Apr 03, 2020 5:20 pm @theq does it actually work ok at full speed? 115200?
Oh yeah. Works like a charm!
supaduper
Post by supaduper »
Great work guys :dualthumbup:
matt020
Post by matt020 »
Is anyone considering flashing/programming the ESP8266 modules to suit the end user, and selling them as "ready to go units".
Reason I ask is, I'm really only after 1 unit, and its a fair bit of mucking around to get 1 unit going. But if someone who has them working is willing to pump them out and at a price that covers there time to do so, well, maybe people like me would take it up?
I would like an ESP8266 unit, set to a 10.0.0.x IP, with my specific wifi SSID, etc.... I'm located in Australia. I can pay with Paypal.
matt020 wrote: Sat Apr 04, 2020 10:47 am Is anyone considering flashing/programming the ESP8266 modules to suit the end user, and selling them as "ready to go units".
The ESP unit needs to be set to 192.168.240.1 client side and it will DHCP on the wifi side. Client side there will only be 2 IP's so there is no need for any other class of network. Its effectively a NAT router.
I've been trying to persuade @supaduper to ship them with TF3xx boards.
supaduper
Post by supaduper »
Hi Matt
Yes Steve and me have spoke to each other about this and I have ordered some units so when I perfect the method for flashing the firmware than yes I will provide the pre flashed modules and probably the 8 way header for the TF330
matt020
Post by matt020 »
Cheers, thank you Mark, thank you Stephen!
matt020
Post by matt020 »
Okkaaaaaaaay. I've bitten the bullet and I have purchased:
Mini FT232RL FTDI 3.3 5V USB to TTL Serial Converter Adapter Module for Arduino
ESP-01S ESP8266 Serial WIFI Wireless Transceiver Module DC 3.0~3.6V 2.4GHz Black
In the firmware folder at https://github.com/martin-ger/esp_slip_ ... r/firmware there are two .bin files, which one do I use to flash the ESP module please?
0x00000.bin applied 0hax's fix to lib_lwip_open_nat 17 days ago
0x10000.bin applied 0hax's fix to lib_lwip_open_nat 17 days ago
matt020 wrote: Tue Apr 07, 2020 10:10 am In the firmware folder at https://github.com/martin-ger/esp_slip_ ... r/firmware there are two .bin files, which one do I use to flash the ESP module please?
Read the instructions...
https://github.com/martin-ger/esp_slip_ ... d-flashing
matt020
Post by matt020 »
Thanks.
I'll be using Windows to flash, so I'll see whats available to flash both .bin files.
Ta.
