Yes.rubber_jonnie wrote: Thu Mar 26, 2020 1:36 pm @exxos I presume if you're going for IDE board based TOS, then you should leave the H4 ROM socket empty?
Yes.rubber_jonnie wrote: Thu Mar 26, 2020 1:36 pm If you wish to use the H4 ROM socket, then the IDE ROM socket should be empty?
No. If you use a jumper wire from the IDE ROM CS line as in my guide, you can use that on the jumper on the H4 above the SMT GLUE.. Remove the linka and put the IDE ROM CS wire to the left pin.rubber_jonnie wrote: Thu Mar 26, 2020 1:36 pm Also, I presume that even with the IDE board fitted, you cannot use TOS 2.06 from the H4 socket, it has to be in the IDE board?
While its possible to do that, I don't think there is any real benefit to it, I just noticed it as someone would bound to ask how to do it.
