27C400/27C800 EPROM emulator
PaulJ
Re: 27C400/27C800 EPROM emulator
Post by PaulJ »
Well, built a prototype board to use the rom emulator on a mega4 but have achieved no joy. Programmed byte reversed and not reversed both work the same. Video garbage is the best I have achieved. Diagrom just gives a white screen. Assuming Lighting ST provides a cs for $FC000, $E00000, and 0 through 7 since it takes cs from the mega4 rom pin 20 u9 or u10.
cmorley
Post by cmorley »
I can't speak for the /CS & /OE on that system. I assume you tied /byte to Vcc. Any of A18, A19 and R which are not connected should be set to pull up in the module's software. The STM32 has open-drain outputs so without pull ups (internal or external) the voltage will be floating.
PaulJ
Post by PaulJ »
I have connected /byte to +5. I received the second unit replacement yesterday in great shape... thanks for the additional packing Chris. So I will give that one a try. The current unit works great from the USB side but the no echo on input makes me crazy. Hope you will fix that on newer versions of the software. Also there is a lot of unknowns in the operation so a manual or a README down the line will be appreciated. But as far as the USB operation is concerned it always writes and verifies fine.
Guess I'm going to need to generate my own decode so I can boot off the standard 1.04 rom and examine the code at $e00000. Also I'll purchase a real 27c400 to verify the prototype adaptor. I may try the Atari dogcart with serial. It my get far enough in the code to get that working but I doubt it.
PaulJ
Post by PaulJ »
@cmorley , just curious.. are you still selling them?
cmorley
Post by cmorley »
Sure, I have a few left built up and can always build more if people want them.
I am working on a comprehensive test for them. Got a few things on the list for the firmware too. Plus life gets in the way - so still active on this just quietly with nothing useful to report to the forum.
PaulJ
Post by PaulJ »
@cmorley I would like a couple more in the hardpak. You can leave the pins unsoldered. I can do that here. Let me know the price and I'll pay you via PayPal. Building a prototype adaptor for the H4. Eventually I'll have to make pc boards. :) :)
cmorley
Post by cmorley »
Contract work has been keeping me busy but I did a bit of work on the firmware tonight.
I've added a proof of concept ROM switch if no A0 activity. This should mean on Amiga (at least) you don't have to fit the /RST wire for basic ROM switching. If you want to reset the machine from USB then of course you need one.
I use a register in the CPLD to watch for a rising edge of A0 (on the EPROM) - on the assumption if the CPU is executing code from ROM or RAM then 68000 A1 ought to be toggling. I read that register out over the serial link between the STM32 and the CPLD.
I quickly hacked it in to the STM32 firmware and it works it seems. Interestingly Kickstart 3.1.4 seems to stop and think for 20ms at a time (does it do a halt then wait for v-sync?)...
I've got more code to do to add this properly to the C firmware, then I'll release a firmware upgrade.
One macro cell free in the CPLD - what function can I add to get 100% utilisation :roll:
PaulJ
Post by PaulJ »
@cmorley , it sure would be sweet if when entering programing parameters they didn't need to be entered in the blind. Also I have received the additional two I ordered but haven't tried them as of yet. Thanks for the quick turn around. :)
cmorley
Post by cmorley »
PaulJ wrote: 22 Mar 2020 21:37 @cmorley , it sure would be sweet if when entering programing parameters they didn't need to be entered in the blind.
I'll look at something. I really don't have a lot of code space left ~170 bytes IIRC. You could turn on local echo on your terminal program for now.
@cmorley I saw you mention a bit further up you may still have some for sale, and I am interested in 1, maybe 2. Could you let me know a price please?
Return to “8 BIT CORNER”
