Its 4 extra ICs, 4 caps, a transistor and 5 resistors to do it properly.8 Bit Dreams wrote: 19 Mar 2020 07:28 Would rather solder 2 ics and 2 caps instread of ordering a separate pcb and populate it, however will be happy to any decision.
Best regards,
-8 Bit Dreams
You need to buffer A2-A4, IOR, IOW, IDECS1, IDECS0 as outputs and IDEWAIT and IDEINT as inputs.
Have a look at the A4000 sheets. plus keep in mind that the CPLDs are 3.3v and the signals needed to be put up to 5V.
Its probably worth ensuring that all these are buffered on your board too.
