Tf534 problem with IDE speed
kulamario
Re: Tf534 problem with IDE speed
Yes this I know I got only 1mb chip but I mean about more stable
I bought yesterday 1mb agnus 8372a and now I start afraid waste money
Lynxman
? How do you get 1 MB chip without an expansion?8 Bit Dreams wrote: 14 Mar 2020 21:43 if You install 8372 - You will not need this additional refresh circuit anymore and Your Amiga will run more stable, but You will have 1MB of Chip ram, wich isn't enough for some games and programs..
8 Bit Dreams
- Moderator Team
Be careful while removing Agnus if You don't have a proper plcc extractor. you can push Agnus out of the socket from underside, there are two holes in the motherboard.
Remove PCB and wire and then reset jumpers to 8372 settings, and You'll be good.
Adding trapdoor expansion will increase risk of instability as ram timings will be slightly shifted. this is something we had on TF530 build with PeteAUs expansion where GARY adapter for SlowRAM was used..
8 Bit Dreams
- Moderator Team
A. by removing existing chips and installing bigger ones,
B. By solderind additional 4 ram chips
http://www.amibay.com/showthread.php?47 ... e-H-W-pr0n!
kulamario
Can I use this from A501 board ?
8 Bit Dreams
- Moderator Team
We are going in circles8 Bit Dreams wrote: 14 Mar 2020 22:27
kulamario
i mean about just chips from A501
no connect A501 to amiga
Lynxman
I didn't know replacing the existing chips with bigger ones would work without more mods. My Rev 5 doesn't have unpopulated RAM holes. I will consider that if I cant' get the expansion to work reliably.
8 Bit Dreams
- Moderator Team
Replacing 4 existing chips with bigger ones was meant to @kulamario's rev.6
Rev.5 Motherboards need more modifications to make it possible
kulamario
Can u tell me what exactly use for this please
