PaulJ
Just feed Harry.. looked a little lean. :girldance:
I just helped to fatten him up a bit as well :lol:
He should be quite happy now, I've also fed him :)
PaulJ
I knew down deep Harry is a glutton.. :sigh:
Oooh I forgot this: :girldance: :girldance: :girldance:
PaulJ
@exxos , what is the IDE connector pin pitch on the new 1.1 IDE board? Thanks
DoG
Check the part list/BOM in this thread. But I can help you right away, it is 2mm :D ;)PaulJ wrote: 16 Mar 2020 18:25 @exxos , what is the IDE connector pin pitch on the new 1.1 IDE board? Thanks
PaulJ
Oh, its the 0.0787 pitch instead of the 0.1 pitch used on the initial board. :) :)DoG wrote: 16 Mar 2020 20:31Check the part list/BOM in this thread. But I can help you right away, it is 2mm :D ;)PaulJ wrote: 16 Mar 2020 18:25 @exxos , what is the IDE connector pin pitch on the new 1.1 IDE board? Thanks
It's 44 pin ide isn't it, rather than standard 40 pin.
PaulJ
Yup, the initial board used a header with 0.1" pitch. So the 0.0787402" pitch are the smaller connectors used with the 44 pin. Guess I'll have to order some one these header pins.
