RJ's Attempt. Maybe he's going to finish this time!
Re: RJ's Attempt. Maybe he's going to finish this time!
Well done @rubber_jonnie - I will drop an H4 mug into the post for you.
Yeah the dot on the chip goes to the * on the board.rubber_jonnie wrote: Thu Mar 05, 2020 7:04 pm @exxos Well, I put the dot up towards the L/H rear corner of the board (I think there was a * there), is that correct?
@exxos Cool, I will remove/rework/etc and see what comes out of it.exxos wrote: Thu Mar 05, 2020 7:10 pmYeah the dot on the chip goes to the * on the board.rubber_jonnie wrote: Thu Mar 05, 2020 7:04 pm @exxos Well, I put the dot up towards the L/H rear corner of the board (I think there was a * there), is that correct?
@Icky I would make it my preferred beverage conveyanceIcky wrote: Thu Mar 05, 2020 7:08 pm Well done @rubber_jonnie - I will drop an H4 mug into the post for you.
Ok, @rubber_jonnie you can tell us now how long have you had it running? You were just screwing with @PhilC right. Anyway congrats!! Nice job!!
Hahaha, well good for @rubber_jonnie if he was as he had me fooled if so.
I'm overjoyed to see that RJ has got it up and running as theres nothing quite like seeing a computer youve built spring in to life.
That and now RJ has fixed his H4, he can help break some of the other stuff. This breaking is time consuming hard work.
@PaulJ Literally had it running since about 17:20 GMT today!
I just had the idea to use the IDE interface to give it a ROM and that did it.
I'm overjoyed too @PhilC!PhilC wrote: Thu Mar 05, 2020 9:28 pm Hahaha, well good for @rubber_jonnie if he was as he had me fooled if so.
Now tell me what I can break!
RJ, we knew you could do it... just need the proper incentive..rubber_jonnie wrote: Thu Mar 05, 2020 10:49 pm @PaulJ Literally had it running since about 17:20 GMT today!
